In the following I want to meet a catamaran made of balsa with hardware home made
Home made balsa catamaran
to increase the resistance we put on a whole surface of the reinforcement fiber glassAttached FilesComment
port propeller tubesComment
assembled and ready for paintingComment
final
Length= 1000mm
Width= 320mm
height= 120mm
engines = 2 x Roxxy 3656/04 , 20V, 60Amp
batteries = 2 x 5 cell Li-Po 2200mA, 33C.
ESC = 2 x HiModel Navy Fly-70-Opto, Cooling water
Propellers = 2x 42mm pitch 46 , 2 blade carbonLast edited by OldMann; 04-26-2009, 09:12 AM.Comment
Thanks for the feedback, really was a lot of work. But the satisfaction is great when you see that everything goes as you want.
Meanwhile I redid the painting catamaran and I made new couplings and tube port propeller. They will be mounted on the new catamaran that is working. Il catamaran built after the plans received from "lomdel. I will try to increase the size slightly.Comment
New catamaran
I started construction on another catamaran.
I finished the propulsion and rudder.Comment
