30" Scratch Built Cat
  • Jeff Wohlt
    • Jan 2008
    • 2716
    #226
    Fits the UL1, Elam, Vegas and most monos. SVs no problem with the brackets that come with it.
    We pay so much attention to resistance and this is a no brainer to help eliminate just that. You do have to sand the stub down slightly since 187 bearings are really about 185. chuck it in a drill and sand it a bit. Bearings are good for about 45,000 rpm but change to ceramic and you are good for about 80,000...like anyone could do that.
    www.rcraceboat.com
    [email protected]
    • Jesse J
      scale FE racer
      • Aug 2008
      • 7116
      #227
      What are you talkin Jeff, why do you think they make the 4mm props for?
      "Look good doin' it"
      See the fleet
      • Jeff Wohlt
        • Jan 2008
        • 2716
        #228
        I am talking the new strut with 3/16" shaft.
        The other strut in the upper thread is a 4mm shaft that steps up to 3/16". I can make whatever you want to work...4mm props are fine as well.
        I would rather use a 3/16" hub prop when we can...since the majortiy of of the props we use are Octura.
        www.rcraceboat.com
        [email protected]
        • Jesse J
          scale FE racer
          • Aug 2008
          • 7116
          #229
          Actually, I was teasing, and meant a prop with 4mm od not shaft size.... and referring to your 80K rpms comment.
          See the fleet
          • Jeff Wohlt
            • Jan 2008
            • 2716
            #230
            Ha...I get it. A little slow this morning.
            www.rcraceboat.com
            [email protected]
            • jesflorida
              • Apr 2009
              • 69
              #231
              Originally posted by lomdel
              I managed to redesign the plans to 810mm length with a 150mm wide tunnel and modified it so that brace F becomes a slightly tilted plywood twin motor mount. The plans are available as JPG, PDF or DXF for those who want it... That is a CAD rendering below, not the real thing yet.
              The single drive version is also available in the same format.
              I would like a set of plans of the 810mm x 150mm tunnel width for lazer cutting by Al Guzman.
              What is your price sent to me via email?
              What is your price sent to me on disc?
              Thanks,
              jesflorida
              • lomdel
                • Nov 2008
                • 708
                #232
                jesflorida
                Jes, PM me your e-mail address and I will send them for free.
                Guys, my build is progressing a bit. Paintwork is finished although not perfect, but for a first try and with rattle cans it turned out just fine. Next will be hardware install and decals. The rudder and stingers already mounted. The cockpit is a butchered SV27 canopy mounted far back to get that long nose sleek cat look.
                • kennyrach
                  • May 2009
                  • 94
                  #233
                  Hello all and rawsonreyes did you take picture of the kit yet and how it coming along m8
                  http://kennyrachtrains.com/
                  • kennyrach
                    • May 2009
                    • 94
                    #234
                    Hi all ,If anyone need to Calculators for Conversion for Units of Measure .you can use this free Units of Measure Online Conversion Calculatorsat tower hobby at http://www.towerhobbies.com/help/convcalcs.html .hope this help you all
                    • lomdel
                      • Nov 2008
                      • 708
                      #235
                      Whaaat! No comments on my cat in post #232?
                      • kennyrach
                        • May 2009
                        • 94
                        #236
                        Hi lomdel it look super m8 and what Stinger Drive are you using .and are you going to kept the color black and white ?
                        • lomdel
                          • Nov 2008
                          • 708
                          #237
                          It is actually not black, but Navy blue. The stinger is the Etti one as below...
                          The rudder is a Graupner one from Cornwallmodelboats.
                          • kennyrach
                            • May 2009
                            • 94
                            #238
                            Originally posted by Norman2
                            Hi, I have a hatch with twin cockpits from a ProBoat Apache 24 which could be
                            used for Cats or Monos. Please let me know if anyone can use them and I will
                            ship free. This would be easier than styrofoam. Attached Photo.
                            Norman
                            HI m8 what the cost for this hatch with twin cockpits from a ProBoat Apache 24.i can use it
                            • Jesse J
                              scale FE racer
                              • Aug 2008
                              • 7116
                              #239
                              Lomdel, very nice looking build. I really like your paint scheme, how about shooting some pics in the sunlight during a float test? Great struts! I am ready to see her wet. Do you have any recent pics of the innards? Lookin good and SV lid works out real nice. Good job!
                              See the fleet
                              • rcboatfan
                                • Aug 2008
                                • 253
                                #240
                                looks awsome! great job!
                                SUPERVEE 27 37'' TWIN CAT
