arming problems
  • launchpad
    • 194
    arming problems
    Hello there;
    I have a bit of a problem and I hope someone could help.I converted a Miss Vegas over to brushless everthing went great except in the arming.Here is what I do,turn the transmitter on and then plug the batteries to the esc.I pull back on the trigger and when I let it go the motor kicks in but when I push the trigger forward it will stop.Does anyone have any idea why this would happen.
    Thanks Guys
  • Basstronics
    • Jun 2008
    • 2303
    Whats esc is it?
    My ESC has a rather strange arming procedure my first one didnt...
    • launchpad
      • 194
      The esc is a hextronic 120 with programming feature.
        • 7990
        Depending on your transmitter, you may need a PiStix to make the Hextronic work correctly. If your transmitter has enough EPA and trim adjustment you might be able to get it to work without one, but you should consider a PiStix anyway.
        • launchpad
          • 194
          Hello;
          Thankyou for the info,would you know where I could obtain one of these Pistix things.Considering all facts,I wonder if it would be more practical to just get a marine esc instead.I checked out this pistix and they are apparently hard to find.I have been informed that Steve from OSE might be able to help as he is in contact with someone inregards to this thing.
          Anyway;thankyou for your input. Al
