I thought some here would like to see one of Brian's Raptor P-Spec riggers being assembled, so here we go.
I'm going to keep this kind of shorter... mostly just pics and quick descriptions, but hopefully my take on putting one of these together helps someone out there.
Thus far, I have the motor mount drilled up and have installed the motor mounting blocks. I have decided that I may move the motor back another 1/2" to 1" to give me a little more room up front, but we'll see how things layout.
Rather than glue the booms in, I've decided to try making them adjustable, like the Nitro guys do, so I've fabbed a set of hardwood blocks with threaded inserts that the booms will bolt down to.
To solve the problem of how to seal the booms, I'm going to try using some of the Dubro pushrod seals. The hole in the aluminum mounting ring leaves plenty of room for adjustment, so I think this will work fine. Snip a little bit off the end of the rubber boot, and they fit nicely over the booms...
