Hi there
No trim tabs no turn Finns just as it is, i have a MHZ Lizard Xtreme setup the same way and it seems to run and turn just fine without it,i will see what happens with this boat
Here a few pics and a vid
Very nice and fast boat as well. I am surprised it runs so well without pulling to the right without trim tabs. Mine does. Are your weights distributed equally left and right? Do you have any secret...?
Hi
No secrets this boat runs strait as a die Cg around 31-32 % 87.6 kmh on that run best speed so far 91 kmh with modded Abc H5 prop i got some new batt coming will run 7S next time
Thanks for looking
Cheers Adrian
Please excuse my OCD and ignorance, but it looks to me like you had a good 'ol time with the drill making your hole in the transom for the stuffing tube!
Looks from the inside like it's nicely filled, but the hole appears to be there from the "outside" pictures.
This boat is setup with a bell inside the boat and the furrel that the cable connect to sits inside this bell the hole on the transom of the boat is oval so the strutt can be adjusted up or down
Take a good look at the pics and you might figure it out
Adrian
