DF Sniper build
  • Punisher 67
    Ignore list member #67
    • May 2008
    • 1480
    I just want to thank everyone for there support and nice comments
    Jeff the cooling tubes will be mounted tomorrow
    Douggie I will start off small as usual , probably a x455 or equivalent
    Necessity is the mother of invention.............
    Youtube Video's http://www.youtube.com/user/Titanis2000
    • Punisher 67
      • May 2008
      • 1480
      Originally posted by Jimmy Sterling
      I see, I see
      Wish I had the facility's to engineer gear like that
      Jimmy twelve months ago I bought a CNC taig mill of off ebay for under $2000 with not a clue as to how to run it , joined the mach3 forum and within 3 months got a fairly clear understanding on how to write my own G-code in notepad and make some really cool things , anyone with the time and enthusiasm can with time get real proficient with what ever they design . being the dumbass that I am I surprise myself every day
      What I am trying to say is that anyone can do this in fact I could teach a grade 3'r G-code in 15 minutes
      • lomdel
        • Nov 2008
        • 708
        How does a drawing file like DXF or DWG translate or get converted into G-code? Can you point me in the direction of a G-code support forum(mach3)?
        • Punisher 67
          • May 2008
          • 1480
          Lombard I havent quit gotten that far as to convert DFX or DWG , but I am getting fairly good at writing my own 2D projects , for 3D I will need to learn a Cad program..............near future . mach3 is the program you will use to control your CNC mill , great program and very easy to learn , you can download the demo which is still full featured up to 500 lines of code and play with it on you computor or laptop . I messed with it for months before the mill arrived just to get a good feel of what I was doing , you can also download the 150 page instruction booklet in PDF format , I got my son inlaw to print it out which is handier than reading it on the screen
          Mach3 forum.............http://www.machsupport.com/forum/
          Mach3 download..........http://www.machsupport.com/downloads...n3.042.022.exe
          • txboatpilot
            • Oct 2007
            • 1494
            Very nice build,,, love the motor choice! I am waiting on my 2230/1Y to arrive, should have it in a couple days.. I am going to test it in my Cat's first,, but really intend on building a Mono.. I like the DF Sniper alot, but also like the looks of the Herzog Hurricane..
            I would love to see some video of this beast in action!
            Nothing like keeping you lipos warm and your prop wet!!
            • Eyekandyboats
              • 1921
              so where do i send my paypal?
              or would you prefer a money wire transfer over my offshore bank account ?
              EYEKANDYGRAPHICS
              www.rclipos.com
              • Steven Vaccaro
                • 8720
                Peter as normal for you, its outstanding work. I have one question, with the cooling tubes mounted in the motor mount, is there any change a slight twist in the rails will damage the esc? I guess I'm asking is if the tubes are in there tight or floating?
                • Punisher 67
                  • May 2008
                  • 1480
                  #23
                  Steven there is absolutely no twist , the unit is solid as a rock ( like a chevy ) it has frame connectors each side that joins the front mount to the rear , the ESC floats on the silicon tubing but is in there tight
                  http://forums.offshoreelectrics.com/...8&d=1233452672
                  • Steven Vaccaro
                    • 8720
                    #24
                    I forgot that the mount was attached, front to back. My worry was that the esc cooling tubes are attached to the sandwiched plate and that the twist may cause a separation, but you got that covered.
                    • Steven Vaccaro
                      • 8720
                      #25
                      I hope like a new Chevy! My 7 year old Chevy Avalanche will shake the teeth from your mouth.
                      • Punisher 67
                        • May 2008
                        • 1480
                        #26
                        Actually Steven I'm a Dodge man , I have a Dodge ram 3500 one ton dually....my glorified car.............
                        Cooling tubes mounted and connected................. and a rear shot
                        • ksm2001
                          • Jun 2007
                          • 377
                          #27
                          Looks great Peter with the stainless steel cooling tubes. WOW I see you took it for a rip outside....turned that pond to snow.
                          Ken
                          DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
                          • Bill-SOCAL
                            • Nov 2007
                            • 1404
                            #28
                            I'd recommend building a floor for the center line packs so they sit flat. Easier to tie them down that way. 6S packs have a lot of mass and you don't want them flying around inside the boat. The side packs are held in place nicely and cannot fly around easily.
                            Don't get me started
                            • Punisher 67
                              • May 2008
                              • 1480
                              #29
                              That is also on the menu bill , probably will be a lexan subfloor with a wingnut clamp system and velcro
                              Ken thanks , yeah a big rip in the snow.....
                              Richard for sure there will be a video
                              Bill Is there a chance you can post a picture on how you keep the front of the hatch down.....
                              • Bill-SOCAL
                                • Nov 2007
                                • 1404
                                #30
                                Sure. Just send me one of those really nifty cooling jackets and the servo/RX mount and I'll snap all the pictures you want!!
                                In the mean time, I use a simple carbon fiber plate that goes into a groove cut in the lip of the hull at the front of the hatch opening. I use two small wood screws into a palte in each rear corner for added security. Then I tape it up for water proofing. So far it has held up pretty well.
