how to modify a KB45 motor
  • bustitup
    • Aug 2008
    • 3071
    #31
    Jeff
    Great tips
    I bought some 4mm brass tubing from ose......any tips on mounting the drilling for the inlet outlet?
    Looking forward to your pics
    • Jeff Wohlt
      • Jan 2008
      • 2716
      #32
      I would not bother cutting those angles. (Just me I guess) I will use the 10/32 or larger pressure fittings and drill them tight and screw in with some epoxy on them. Or small lengths of KS is fine too but always wiretie the tubing since there is no nipple, I even use those for nipples. Make sure they are flush inside before gluing. You need a couple mm clear..or 3. around the can for water....the flow and pressure will do the rest. Unless you need the room, elbows do nothing else. Water will always flow to the exit or where there is the least amount of resistance...the exit. :)
      I seal with silicone as shown. I like the extra protection. If you need it off a small cut with exacto knife around the can and remove it.
      I like to place my inlets/exits where I need them....many seem to make it hard for tubing. My exit is always on the rear side of the can and right out the hull...almost a straight shot and I can see flow as it passes by.
      Getting good water flow to the motor and ESC is the key, which is all about the pickup but also not having tubing all over your hull with bends and kinks.
      There are tons of o-rings out there that can fit just about anything...my Ace hardware must have 100 sizes of o-rings.
      Good post...I may even make some out of the FG cloth I have here. CF is the cool look but that is about it.
      Man....I better slow down on the coffee!
      www.rcraceboat.com
      [email protected]
      • bustitup
        • Aug 2008
        • 3071
        #33
        yes those 10/32 fittings are nice...what is KS?...where are the pics?
        • bustitup
          • Aug 2008
          • 3071
          #34
          hmmmm just found these....?
          Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
          • Jeff Wohlt
            • Jan 2008
            • 2716
            #35
            No. These. Also, there is your 90 degree fitting....They are all out...I bought them all :) Not really...all they had, which were not many.
            K&S is just brass tubing
            www.rcraceboat.com
            [email protected]
            • H2OCamel
              FAST ELECTRIC EVERYTHING
              • Oct 2007
              • 484
              #36
              Great info! I will have to mod my KB8XL.
              "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
              • crabstick
                • Jul 2008
                • 954
                #37
                Would this method of opening the can mash the bearings?
                I just got a kb45 today and it has no endplay at all so im going to have to open it up and remove a shim.
                I thought I had read somewhere that the front plate unscrews, but then I guess I have to pull out the rotor to get to the shims.
                Thoughts please
                Matt.
                FE, Nitro and Gas racing in Auckland
                www.rcboats.co.nz
                • EPower
                  Banned
                  • 391
                  #38
                  Thoughts please
                  Mine had no play whatsoever after the first run it had about 1.5 mm don't bother opening it just a waste of time, the front plate does unscrew, only one brass shim in mine
                  • crabstick
                    • Jul 2008
                    • 954
                    #39
                    Hi Adrian
                    Was planning to replace the Bearings anyway, but i may just run it and see. How were the temps on yours ?
                    Matt.
                    www.rcboats.co.nz
                    • EPower
                      Banned
                      • 391
                      #40
                      Hi Adrian
                      Yeah just run it as it is you can replace the bearings later, ran warm but have a large water jacket, i still have some carbon tube if you want to make one yourself
                      Cheers
                      • crabstick
                        • Jul 2008
                        • 954
                        #41
                        Cheers Adrian, I am keen on the tube!! Found some replacement precision bearings out here in pukekohe, $8 bucks each will be here in the morning.
                        Matt.
                        www.rcboats.co.nz
                        • nate
                          • 1652
                          #42
                          Motor mount was wicked!!!
                          LMT
                          LehnerMotorenTechnik.com
