Hi Guys,
Last year I got an SV27 as my first FE boat. Before I even ran it I redid all the inside wood with aircraft grade ply, changed the speed control and radio, upgraded the prop, cooling, extra turn fin, etc. I ran it on 4s2p A123 cells. It was a lot of fun, but I want something better for the rougher water conditions where I run. This will be a sport boat and my first "build"
Is it worth re-using the SV27 hardware - is it "good enough". I want to make sure it will work ok before I drill some holes in my beautiful Titan 29 hull. Is there is a big difference upgrading to speed master hardware?
How far should the rudder extend below the prop? - 2"?
How far from the bottom of the transom should the prop shaft hole be located?
I am concerned that the SV27 turn fins are not long enough. Is there any documentation around on how they should be located?
Any other tips for setup. I did a search on the titan and got a fair bit of hits, but its seems mostly to deal with power setup.
Thanks!
Cheers,
Dave
Thanks!
Cheers,
Dave
