53? Delta Force Annihilater Build
  • pescador
    • May 2009
    • 499
    This is my Annihilater build for 10S with a Neu 2230, Swordfish 300 esc, and a flooded stuffing tube.
    This is the same setup I ran in my now retired Twincraft hull.
    Namba District 16
  • Brothers 1718
    • Jul 2017
    • 132
    I like seeing more big electric boat builds, hopefully the manufacturers take notice and make more high amps escs. Will you be inlaying carbon in the hull?
    • pescador
      • May 2009
      • 499
      I did inlay it, I?m catching up with my posts it?s pretty much done.
      Namba District 16
      • pescador
        • May 2009
        • 499
        I made paper patterns for the cf inlay, and cut them out with a rotary knife.
        Made a bulkhead out of cf sheet to help with the front deck flex. I cut it out with a dremel diamond wheel and a hole saw.
        Namba District 16
        • pescador
          • May 2009
          • 499
          Cut out the transom inlay, finished the hull inlay and glued in the bulkhead.
          Namba District 16
          • pescador
            • May 2009
            • 499
            Put together the flooded stuffing tube, the end cap I turned on the lathe.
            Test fitting the motor and stuffing tube. Did a lot of test fitting with all the hardware to get the cg reasonable. The motor is pretty heavy [emoji3]
            Namba District 16
            • BUMBLESPECIMOODA
              • Feb 2023
              • 220
              Nice build. I love it.
              Question: Is the flooded stuffing tube, to allow more range of adjustment for the strut and prop angle?
              • fweasel
                master of some
                • Jul 2016
                • 4291
                Yes.
                Vac-U-Tug Jr (13mph)
                • pescador
                  • May 2009
                  • 499
                  The hardware is on.
                  Battery trays
                  Servo mount
                  Just have to set the trim tabs
                  Namba District 16
                  • autolex
                    • Sep 2021
                    • 84
                    Beautiful work! what kind of battery sizes and runtimes are you expecting here?
                    MHZ Mystic 84 (BUILD) | DYMotorshop 750mm Mono (BUILD) | BlackJack 24 of Theseus (54mph) | ProBoat JetJam (toy) (BUILD) | Noodle Recovery Scaffolding (6.6mph)
                    • pescador
                      • May 2009
                      • 499
                      I ran the same setup in the Twincraft with two 5000mah 5s packs and had no problem lasting a race.
                      This hull has room for 4 packs if I can come up with a bunch more. [emoji3]
                      Namba District 16
                      • ray schrauwen
                        • 9475
                        Awesome!
                        Nortavlag Bulc
