American Express Yacht conversion. Need some help selecting parts.
  • Erik Starcher
    • Jul 2024
    • 4
    I have been converting the American Express toy yacht to Hobby grade.
    Current hardware: 4mm straight shaft, 55mm turn fins, 95mm rudder, 40mm Aluminum prop from the UDI Arrow, 2200KV SSS 2960 motor and 50A Flycolor ESC.
    She runs nice and stable at 20-25MPH but is running very wet and not coming up on plane.
    Due to the size of every motor I have tried, the prop is pointing down a bit and I cannot get the shaft angle parallel to the keel.
    Only way I could would be to use a universal joint and I do not want to go that way.
    I have decided to move to a flex shaft with a bend in it so I can get the prop angle right and get the boat up on plane.
    Now, on to my question: Flex shaft-Stuffing tube options.
    I picked up the Micro Strut for a 4mm prop shaft from OSE and need to choose a flex shaft and stuffing tube for it.
    The strut has space for a 5mm stuffing tube to fit into it so I would like to stay with that size but not sure if I should go with the thin or thick wall tubing.
    From what I gather I have 2 options:
    1: 5mm thick wall (5mm OD, 4.1mm ID) and .130 cable with 4mm shaft. That would give me .62mm clearance on each side of the cable.
    2: 5mm thin wall (5mm OD, 4.55mm ID) and 4mm cable with 4mm shaft. That would give me .275mm clearance on each side of the cable.
    I would prefer to use the 4mm cable but not sure that would be enough cable clearance in the stuffing tube with a shallow bend in it.
    Also, the 4mm cable has a 70mm long prop shaft and the .130 cable has a 76mm one. That would make the flex cable end of the prop shaft stick into the stuffing tube 7 to 13mm so I cannot go any small I.D. then 4mm.
    I will be using a 2100KV 42mm Outrunner motor (Proboat Recoil) on 3s and moving the 2960 SSS motor to another boat if that makes a difference in your suggestions.
    Let me know what your thoughts are please? Don't want to get the wrong combo and waste the money and need to rebuild it a 3rd time.
    I will post up some pictures once I figure out how.
    Thanks for your input!
  • Erik Starcher
    • Jul 2024
    • 4
    Pics
    Here are a few pictures of the work in progress.
    • BUMBLESPECIMOODA
      • Feb 2023
      • 219
      Coming along nicely. I've learned in all my hobbying, there is no "Wasted money". It's all lessons learned. Think of the costs like tuition.
