Hi fellow RC boaters,
I share my latest project with you: a 20" Mini Mono, based on John Finch Wildthing. I redesigned the hull, with slightly bigger V at the bow, and a different bulkhead design.
I share the plan for free, this is the download link: https://drive.google.com/file/d/1KJ7...w?usp=drivesdk
It is an easy build, perfect for entry-level boaters. Even better: it's a budget build too. For about $250,- RTR with lipo and charger, or below $200,- if you already have a transmitter and charger.
The bulkheads are 2.5-3mm thick plywood. The plating is 1.0mm birch plywood.
The motor I used is a 28mm 2600kV inrunner. The esc is a ZTW 50A water cooled version. A cheap mini servo and rudder with water cooling pickup, takes care of the cornering
I'm using 3S and 4S 3000mAh lipo's. The turn fins and trim tabs I made myself, but cheap alternatives are available (see drawing).
Ready to run! Including the lipo, it weighs just 873grams.
Verstuurd vanaf mijn SM-S911B met Tapatalk
