58mm Motor Mount
  • GeckoDragon
    • Nov 2023
    • 26
    58mm Motor Mount
    Okay, one last question yall. I'm putting in a TP Power 5870 (58x123mm can), and having a hard time finding a 58mm mount. Anyone know if the OSE 56mm mount for 5" rails would work? 30mm 6 bolt pattern
    https://www.offshoreelectrics.com/pr...prod=ose-83403
    Thanks!
    Prather 46" Deep Vee (electric conversion)
    Horizon Harbor Tug
  • fweasel
    master of some
    • Jul 2016
    • 4286
    If you go with a 5680, you'll have more mounting options. Can't say I know anything about what you're building, but just an idea to consider.
    Vac-U-Tug Jr (13mph)
    • GeckoDragon
      • Nov 2023
      • 26
      Gas->Electric conversion for my old Prather 46" Deep Vee. Probably went a bit overboard with the motor, but no going back now20240130_190242.jpg
      Horizon Harbor Tug
      • tbonemcniel
        • Sep 2020
        • 295
        Originally posted by GeckoDragon
        Gas->Electric conversion for my old Prather 46" Deep Vee. Probably went a bit overboard with the motor, but no going back now[ATTACH=CONFIG]178729[/ATTACH]
        I'm not sure of a mount with rear support ring for a 58mm can. Mounts for Lehner motors are for 60mm cans. You may have to custom make something, as I'm not aware of any off-the-shelf mounting options for a 58mm can. It's possible this one https://www.offshoreelectrics.com/pr...d=ose-80974-v3 could be helpful, as it uses an o-ring on the rear support. I'm not sure if there's enough clearance, but you could possibly order a 1mm thinner o-ring and make that work?
        And not a question you asked, but just those two Zee packs in series aren't going to be capable of supporting very much power. That motor could demand 4-500A propped hard enough and while your ESC can dish it out, I guarantee those batteries cannot. I just don't want you to be disappointed if your electric conversion doesn't have the power you expect. That's the first place to look harder at.
        • GeckoDragon
          • Nov 2023
          • 26
          Thanks for the feedback. Agree about the Zee packs. Not what I plan on running, but I got them for a song from a relative and figured I could at least use them to test things. The plan is to run a pair of 10 or 15Ah 4s in series for 8s, probably CNHL
          Horizon Harbor Tug
          • Alfa Spirit
            • 2131
            This TFL HOBBY motor mount is made for 56mm and 58mm motors
            • tbonemcniel
              • Sep 2020
              • 295
              [ATTACH=CONFIG]178774[/ATTACH]
              That looks a lot like the one I linked to with the o-ring rear support, only without the top cross brace. Possible that o-ring rear support is only added to reduce the 58mm design to 56mm?
              • GeckoDragon
                • Nov 2023
                • 26
                Can you provide a link to it?
                Horizon Harbor Tug
                • rewfas
                  • Apr 2024
                  • 1
                  Can it be reduced to a 56mm design even if the function remains unchanged?
