Hi fellow boaters,
Last year I built a 32" Wildthing that I slightly modified. It started as a 60+ mph boat build, but it proved to be quite a bit faster with 75mph top speed.
I enjoyed the build and performance so much, that I decided to build a twin mono. It is again based on the Wildthing, but I modified the design a lot. This boat is 33.5" and will get dual stinger drives and a 6S setup. Most likely 2x 3674 2000kV motors and 150A Flycolor esc's.
Here's the design, although it still had a single motor setup here:
I cut the frames and set them up at the building board.
I also upload the build on YouTube, if you are interested:
Next step is apply the bottom and side sheeting and release the hull from the build board.
