np, anything I can do to help.
My Micro Hydro
Sounds good. You still want my templates?
Question for Randy/Doc.
I notice that neither the hull edge or the deck edge is cut straight. What should I do to the hull to ensure that I get a good, even, twist free hull when I go to glue them together?
If I had a really big belt sander I would smooth the hull on that, but I don't.
I set up my hulls on a building board. Then I set up the framers or carbon fiber chassis. If they are stright on the install, the transom will be flat to the table. Pic below.
Oh, I think I know where you are going......
The top of the hull (the deck) is curved both lengthwise and crosswise, so for a proper fit, the top edge of the hull is not straight. I believe you can actually see a faint trim line on the parts.
I use a long sanding block and a lot of trial fitting to get a good joint. I also take a fine line Sharpie pen and go over the trim line so I can see it better. Randy does a pretty good job of suppling the hull trimmed fairly close. I imagine many people have just glued them together as supplied by Randy.
Cats and V-hulls can be formed with a flat top on the hull, scale hydros aren't that easy most of the time.A nation of sheep breeds a government of wolvesComment
Nope, let me clarify.
I am calling hull the bottom half of the boat. I am calling the deck the top portion of the boat that Randy supplies.
The upper edge of my 'hull is not cut straight around the perimeter, and so, when I put the 'deck' on, it does not line up straight. I can see the trim line in the 'deck', but I see no trim line in the 'hull'. So How do I go about trimming the top edge of the 'hull' straight so the deck, when glued, will be straight?Comment
I use Gap filling CA that fills any gaps, what I am more conserned about is the bottom of the hull and how it sits on the table. The top is a shoe box and fits over the bottom. The rest is just visual. What matters is that the bottom edges are stright and square.Comment
I'm just worried about the 'deck' warping during the gluing process if the top edge of the hull isn't straight.
With this shovel, I have to put a LOT of pressure on the back of the deck to keep the two halves together. I'm going to end up having to wrap it in several turns of masking tape as it easily pulls a single turn loose.Comment
I got started on the frame templates hopefully have them done by this weekend. I'm thinking on filling the sponsons with foam instead of frames.
JIm"Our society strives to avoid any possibility of offending anyone except God.
Billy GrahamComment
