Pursuit jet boat
    • 7673
    Pursuit jet boat
    Good day guys, I have moved to a new area of British Columbia and have been setting the property up so I haven?t posted in some time. But alas my hobby shack is working now so my first project is to convert the dog boat to a jet boat. Let?s start with George
    And my once beloved Bling Rocket
    So the new location has a beach nearby which has a great shallow area and a great space for George to chase the boat. But I need this boat to be a jet boat for safety reasons now. BTW, the boat is beat up from George rescues, he is so proud of himself when he rescues it.
    • 7673
    So this is what I have so far as of yesterday:
    Boat gutted and a TFL jet drive, layout of hole
    My CG should remain close to where it was. Motor is yet to be determined.
    I?m not sure if I should widen the flat intake area or keep as much of the V as possible. I?ll take a few more speculative pics and report back.
    Any input as to motor size and such is appreciated. My thought here is that the boat must be faster than George can run in 1.5ft of water and really prefer it not to just spin out when I turn.
    • a53hoop
      • Oct 2019
      • 65
      where about in bc are you. i am in salmon arm and have no boats guys that i can find any were near,AL
      • Panther6834
        • Apr 2020
        • 708
        I don't know anything about converting a V fire a jet drive...but, I do have a TFL Jet Boat. Looking at the bottom, there is 5mm of flat hull area on each side of the jet drive. I can't get calipers inside the hull to accurately measure spacing...but, to the best of my judgement, I'd estimate there's approx 2-3mm (closer to 3mm) of visible hull of each side of the drive. Not sure if this will help you...but, if it can, all the better.
        ~ More peace, love, and kindness would make the world a much better place
          • 7673
          Hey Al, I moved to the hills just west of Oliver, Fairview area.
          Shawn
          • lilbigmacky
            • May 2020
            • 26
            I'm interested in this as well. I have always been a fan of jet boats and wanted to build an rc one. Im not sure about how removing the v will affect the ride but I know you dont want to restrict the intake because less water in means less water out which reduces thrust.
              • 7673
              Hey thanks for that, does be that hull have any spin out characteristics? I’ve had a couple of the old NQD jet boats(that’s where George started chasing boats). As soon as you juiced em up they started to be straight line boats. So I’ll try a couple hydrodynamic cues from them. I’m thinking a couple small strokes from jet pump intake to the transom.
                • 7673
                Yeah I think I’m going To taper the V forward till I get a desired ride attitude.
                Surprisingly there is little on information on general hydrodynamics of jet boats and such. I have visited this subject a couple times over the years and do have a balsa/ply flat bottom with Graupner jet yet to see water.
                • fweasel
                  master of some
                  • Jul 2016
                  • 4285
                  Jet boats typically have a flat ride pad. I would look at pictures of production models like the Thrasher and the TFL hull.
                  The only experience I have with running one is the Proboat riverjet I rebuilt for a project a few years ago. I would suggest under powering or under-volting it to begin with. Too much power on a jet boat makes for miserable control.
                  Vac-U-Tug Jr (13mph)
                    • 7673
                    Hey there Ryan, yeah I’m going to stick with 20,000 rpm ish, maybe a 1600kv motor or something.
                    • Peter A
                      • Sep 2012
                      • 1488
                      This is a jet boat I built earlier this year (during another lockdown). It was an old nitro flattie hull that I rebuilt to suit. Running the TFL jet unit with a SSS3674 1300 kv and OSE Raider esc on 4s. Runs pretty low current draw, I can get nearly 10 mins out of 6000 mah. I didn't want a super fast boat and am happy with the speed, it would be a fast scale speed, maybe 20-25mph. It does however spin out really easy so in due course I will put strakes on the front of the hull to try and keep the bow up in the turns. I have played with cg and turn fins but do not have it how I want it yet.
                        • 7673
                        Originally posted by Peter A
                        [ATTACH=CONFIG]174180[/ATTACH][ATTACH=CONFIG]174181[/ATTACH][ATTACH=CONFIG]174182[/ATTACH][ATTACH=CONFIG]174183[/ATTACH]
                        Thanks for the pics and input Peter. Great job on that. I have an outrunner at 1100 kv here that is size appropriate, I’m not opposed to a purchase either, I’ll dig around.
                        How many amps are you thinking on ESC then?
                          • 7673
                          So I have the hull cut forward now but the pics should demonstrate the hull attitude I mentioned
                          049F4033-38FB-4B2B-B0AC-7FDC23AC59BF.jpg4A1D1939-5592-41B5-B4D9-BFA9BF79AF91.jpgE3D3641B-DF58-4887-AC06-F1FA86E29325.jpg
                            • 7673
                            I have the pump outlet all hogged out to fit, just need to drill four mounting holes and then it will be fill in the holes time
                            • lilbigmacky
                              • May 2020
                              • 26
                              I might build a flat bottom zippkits crackerbox in the future and put a big ol jet pump in there to see how it works. Id like to see how your jet projects turn out.
