Hi all
I have an SR80 pro that I was hoping to speed up just a hair and also convert to 3/16 prop from its stock 4mm.
Stock motor (1750 KV outrunner) was replaced with a leopard 3660 2050 KV inrunner. The ESC was replaced with a raider 150amp. Battery was kept at 4s. Speedmaster 21 strut replaced the stock. The stock prop was a 40mm unknown pitch, which I replaced with a graupner 42mm 1.4p. Everything is stock. The maiden was rough...heavy accel would pop it out of the water and flip it. Easy accel was ok but I had trouble with it tracking straight. Any hard accel or throttle above 75% and the think would veer one way or another, flip or barrel roll. I tried level strut and even negative angle strut. I added tons of trim tab. Nothing helped. The boat used to be fantastic and I was hoping to just speed it up some. A guy on YouTube has these boats on 6s with with 2200+ KV motors on similar props, but he swears up and down I need to upgrade the turn fins. I can do that..but I?m thinking the prop is too large...my ft011 is 4s and like 2400 KV motor and it?s prop is tiny - and the boat isn?t that much smaller than the SR80. What are symptoms of inadequate turn fins or prop too large?
Nortavlag Bulc
