Electric conversion
  • sakawinkee
    • Mar 2010
    • 17
    Electric conversion
    Hey, Ive got a Arrowshark gas boat 56 inches, looking to put a castle 2028 with a ZTW 300 amp Esc, hoping to run on 8s, any recommendations on prop size to start with?
    Jobs come ang goes, physical beauty fades, stocks rise and fall, great friendships may end, but the benefits of philosophy will last a lifetime.
  • Jesse J
    scale FE racer: Namba 826
    • Aug 2008
    • 7083
    Without knowing what your driving/performance goals are.. all I can do is suggest a reasonable setup..
    Probably wanna run at least 10S2P in this beast!
    Maybe start with 460/3 and check temps after the first minute.
    "Look good doin' it"
    See the fleet
      • 8012
      Jesse is right about knowing your goals for the boat. Considering the size if the boat, if you aren’t looking for 70+ mph then using 8S makes sense because with that setup you can use a gas-sized prop for more efficient thrust. It’s a proven setup on well dialed-in boats. An x470 would be a place to start, but as always watch temps carefully the first few runs.
      • sakawinkee
        • Mar 2010
        • 17
        Many thanks to you fluid and Jesse I just want a normal setup, not for racing or speed runs, just a knockabout rc boat.
