removing motor mount from 36 miss geico
  • Paulkretz
    • Aug 2020
    • 2
    Hello All
    I broke the motor mount in my current mg 36. I have an old hull that I took another mount out of by cutting through the hull. Any ideas on how to get the broken one out with out messing up the hull? I am thinking of using a dremel grinder. Any other thoughts? Is there a way to soften the expoxy for instance?
  • Beerman
    • Apr 2017
    • 3
    Heat gun on low.
    • fweasel
      master of some
      • Jul 2016
      • 4285
      Blast the area with heat. I use an old hair drier to soften the white epoxy. I use a sharp chisel and a small hobby hammer to slide in between the epoxy and hull being careful not to gouge the fiberglass hull. Be careful to not put too much pressure on the hull while pulling or prying as it's easy to crack the gelcoat doing so.
      Vac-U-Tug Jr (13mph)
      • Paulkretz
        • Aug 2020
        • 2
        it all worked out. I only needed to take a portion of the motor mount out....the part holding the stuffing tube. then i just expoxied in the same piece from my old mount into place and was done.....have to get it out for a trial run but hoping it all works out. Replaced the prop strut as well as I think that is where the original problem came from
