crackerbox motor esc options
  • ozboater
    • May 2007
    • 415
    my vac-u-cracker project has been on hold for a while but now i m ready to add the motor and esc... i understand that this is more of a drivers boat than a flat out speed machine but i d like to make it hit the mid 20s if possbile... obviously i don t want to over-power the boat and spend more time fishing it out of the pond upside down...
    i still use matched 6 cell nimh bats for the meantime and thats what i ll be using to power the cracker... can you guys give me some options for brushless power... i m totally open to cheapo chinese motors and escs since i ve had good luck with these in my SV...
    i appreciate and and all advice... the boat is looking good so far and i m stoked to get it in the water in the next month or so...
    • 8012
    When my club raced CBoxes years ago we used ROAR '91 stock 05 motors on 6 round cells and easily got in to the low/mid 20s. The problem was keeping the boat on the water for very long at that speed - that's why the NAMBA SAW record for CBoxes is only 22 mph. You can probably get by with a 380-sized motor although a larger 540 is probably better. Choose a Kv around 4000/4400 in a short motor.
    Tricks that worked to keep me in first place more often than not included:
    - a large turn fin about 3/4" square.
    - a prop no bigger than an x435
    - Minimum rudder endpoints - 3/16" movement to each side measured at the trailing edge
    - trim tabs bent very slightly down below the bottom
    - sanded the bottom with 400-grit wet-or-dry paper used wet
    - keep you eye on the boat at ALL TIMES
    • ozboater
      • May 2007
      • 415
      awesome JT, thanks a bunch... any recommendations on a cheapo ESC ??
      merry xmas
      • ozboater
        • May 2007
        • 415
        ok... so i m thinking about an feigao 8S from steve here at OSE and possibly one of these ESCs...
        does anyone have any experience with the turnigy marine stuff ?? any advice would be a great help tp this newby...
        cheers
        • ozboater
          • May 2007
          • 415
          anyone ??
          • ozboater
            • May 2007
            • 415
            since i seem to be talking mostly to myself the project hasn t progressed
            i was thinging about an 8S but a good friend of mine has made me think... how about a 10S ??? would the cracker get to a decent clip with the 10S ?? would a 60 A ESC handle it ???
            cheers
            ozboater
