Have'nt seen a new Mean Machine build in the past week. So.........
  • Chilli
    • Jan 2008
    • 3070
    Well my son wanted me to build him a Mean Machine for Christmas and I finally got it done. I can't wait for him to see it. Last time he peaked I was just starting to paint it. He picked a paint scheme that I mooched of a cheapo Ebay RTR. I wasnt sure if it would go with the MM's lines but I think it worked out well. This was my second build.
    The hull was a FE layup and the top of the tunnel was pretty flexible so I added a layer of FG fore of the CF. I added a few plywood pads for the RX battery and ESC to sit on. I used a thicker piece of plywood for the stuffing tube support and then went a little crazy with the epoxy putty to seal the tube to the hull. Motor mount is a Vac-u-boat unit. Running gear is the standard Speedmaster fare everyone has been using. Strut is set up a little less than 1/4' from the bottom of the sponsons and about a degree positive on the angle. I ran out of cooling line so that's why there is three of them.
    The motor is something a little different. A Mega 22/30/4 w/ a Hacker 77. that was in my Titan 33. It's a high voltage set up. Should do mid 40's with 24 cells and I'll switch over to 8S Lipos when I recover from Christmas. I'm starting with a X637 Prop.
    The paint was a PITA as I thougth it would be. I have undiagnosed obsessive complusive disorder and must of painted that sucker about 5 times untill I was happy. I couldnt find Krylon at Home Depot or Lowes and settled for some crappy lacquer. Big mistake. It was very soft even after a few weeks and every thumb print and tape mark left a permanent mark. Couldnt even buff it out. So I'm strolling around Wally World and sure enough I stumble accross some Krylon. Much better. Red and silver pinstriping from ebay made for some nice crisp lines.
    Mike Chirillo
    www.capitolrcmodelboats.com
  • Spot Me 2
    • Jul 2008
    • 769
    Very nice!!! Very clean build!
    MMGMMarine
    RobertsonRacing
    • Xzessperated
      • Apr 2008
      • 3060
      Very nice indeed Sir. Your son should be very happy. At first glance I thought it was the Ebay boat.
      Several boats in various stages of destruction
        That is an excellent build, very professional looking. I like the idea of using volts to get the needed wattage rather than using amps with low volts. Easier on everything - and 1400 watts will really move that cat!
        • properchopper
          • 6968
          Sweet paint job. Should be a fun, stable ride !
          • Eodman
            • Sep 2007
            • 1253
            Great build - if your son doesn't like it you can adopt me .... I'm only 57!
            I'm working on 2 MM builds ... 1 is a rebuild and the other is scrach build. With Christmas and life getting in the way its a slow go but I'll try to post some early pictures later today on a seperate entry!
            We did it with a Bang!
            Cats Are Where It's At!
            • ReddyWatts
              • 1711
              Mega 22/30/4
              Have not seen this motor in a boat setup before. I am interested in how well it handles the heat from the 1500 watts. Looks really good.
              Mega 22/30/4
              940 kv, 6-pole, 1000 watts max, 50 amps max.
              Weight 218 (gms), Diameter 36 (mm), Length 53 (mm) Length, Shaft Dia 5 (mm), 87 Efficiency %
              ReddyWatts fleet photo
              • Doug Smock
                Moderator
                • 5272
                Sweet
                Very nice work sir!!!
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • Chilli
                  • Jan 2008
                  • 3070
                  The only boat I've seen run this motor is the Titan 33 mono. There is a gentleman on the Rumrunners site who is mostly into helo's now. He came up with this set up and a couple of us have copied it with no problems, though honestly I only had about a dozen runs in my Titan with 20 and 24 crappy cells. One other person did run this motor with 8S and did not mention any temperature issues.
                  Here are some numbers taken from the first Titan 33 using this motor w/ top notch Nimh cells and a tuned prop.
                  X637/3300 = 5.25min, 42 mph, under 120 cell temps
                  X637/3800 = 6.25min, 42 mph, under 120 cell temps
                  X640/3300 = 4.30min, 44 mph, under 145 cell temps
                  X640/3800 = 5.00min, 44 mph, under 150 cell temps
                  So hopefully this set up will do okay for a while in the MM. I'm getting a infrared thermometer for Christmas and will post some numbers when I get a chance. If I fry something, I'll consider myself moving up a step on the OSE food chain. Notice I made the ESC pad Etti 150 size just in case I want to change the setup in the future.
                  Mike Chirillo
                  • 10gauge
                    • Aug 2007
                    • 281
                    Great craftsmenship in all areas - It's the best looking Mean Machine I've seen. I mounted the antenna in the same location. Wow! 24-cells is going to be heavy... Overall, an excellent build!
                    Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
                    • calcagno45
                      • Mar 2008
                      • 1006
                      Nice clean build!!! I love the paint scheme.
                      • sewerpit
                        • 117
                        getting close to finishing my mm build, do you guys recommend using a BEC or reciever pack . i am using an 8xl and hydr 120 esc thanks
                        • RandyatBBY
                          • Sep 2007
                          • 3915
                          I allways prefer a reciever pack infact a 5 cell I like best. No glitching.
                          Randy
                          BBY Racing
                          • calcagno45
                            • Mar 2008
                            • 1006
                            I second that notion! I use 5-cell Rx packs in everything I use. I picked up a batch of 2/3A cells from Tenergy and Rx leads and made my own packs. Works like a champ!
                            • zypher9
                              • Dec 2008
                              • 8
                              Very nice and clean work, sir.
                              Is there any room for an adoption son?
