Motor Mount install
  • Joejoe
    • Apr 2020
    • 8
    Motor Mount install
    Which adhesive is best to hold down motor mount to the hull and which length screw do I need to mount the Leopard 3674 motor to the heavy duty motor mount 3mm x ? mm
  • fweasel
    master of some
    • Jul 2016
    • 4285
    I like to use West System G-Flex epoxy. I had previously been using JB Weld but have since found that the G-Flex has a little more give to it, making it less brittle when cured, and ultimately stronger.
    Use a toothpick to see how much depth you have on your motor endbell for mounting screws before it hits the windings inside. Then, measure the toothpick depth and subtract a few mm.
    Vac-U-Tug Jr (13mph)
    • Joejoe
      • Apr 2020
      • 8
      Thank you
      • Panther6834
        • Apr 2020
        • 708
        Just curious, but, what about E6000? Would that work?
        ~ More peace, love, laughter & kindness would make the world a MUCH better place [emoji1690]
