Turned out great Pete.
These are a nice rough weather boat. You're gonna love it.
Thanks Paul, nothing really in regards to class racing for it atm, but that is something to work on. Over this covid lockdown there have been a whole bunch of boats getting built in our club, and some new members.
Petrol thunderboats
petrol sport hydros
electric riggers
and now there are 5 1/8 scales in the build process.
Plus there has been a few monos and cats that came up for sale that have been brought by new members.
Club days could be busy, what a problem to have!
Well I finally was able to get enough bits together to finish the boat. It has a flat bottom strut on it atm as the parts ordered from OSE in April haven't turned up yet, I think they are still in a warehouse in Jamaica NY as that is as far a s the tracking got to.
So Saturday afternoon it got wet. Unfortunately due to an insufficient turn fin and needing a lot of rudder it didn't turn enough and ended up in the bank. That shouldn't have been any more worry than wash off some mud, but...some a$$hole has dumped a bunch of large stones there. The clatter sound it made was gutting. Mostly just superficial damage but it sucks to have wrecked the paint and it is a major to sand back the paint and redo it...so a bit gutted on that.
Have some pics but they wont upload?!
Anyway I still gave it three runs. Tried it on a P220, M447 and M445. On the bigger props it was real flighty, even after adjusting the strut and changing the turn fin. Don't kites need string on them was one comment! It was running fast but not stable with a lot of sponson walking and if it got air then...up and over it went.
The first turn fin I was using was an Aquacraft one. I ran the same fin on my whip 20 and it worked fine, but on this boat it needed a huge amount of rudder and it would flex and whip the boat coming out of the turn. I put on a straight large mono turn fin that had been cut down and canted it over a few degrees. This works way better and holds the turns well. I will make a couple of similar ones from 1.6mm spring steel as this one is 3mm thick.
With the m445 I was able to do 6 laps without the boat handling badly, so at around the 50mph mark. It seems better running a bit slower than faster so far. I am wondering if the motor size is overkill and I should change it to a P-Ltd size. I have a TP 5630 1500 kv and a SSS3660 2070 kv I could try.
@Paul, you reckoned this is a good rough water boat, not really at speed so far. Maybe it needs a round bottom strut also. Any ideas for improvement?
Peter, I just read your post. On the website, it does state round bottom strut. Flat bottom struts do not work. I also am seeing a lot of turn fins you have tried that I would say are not good choices. I would stick with the Kevin Macomb fin that Mojo Racing sells, or a Virginia Craftsman fin. Those are the only two I trust. I would also try an X445 or 447, detongued, sharpened balanced, tip cupped. The GP lineup has always run well, and in rough water too. It currently holds the 2 lap record in oval trim for nitro, so I know it moves out. I think right now, you are just needing some tuning done. Also, have you scuffed the sponson bottoms? If they are still gloss paint, that will cause handling issues, and scrub speed. Another thing to do, is cut down your rudder probably 1" shorter. it should only be about 1" to 1.25" deeper than the prop at its deepest point. I hope this helps. Mike, ML Boatworks
HI Mike
Thanks for the input. I have not run the boat since. I still have to finish repairs on the damage and change the strut. The ride pads have been scuffed. How do I get hold of one of those turn fins? It is fast, it just was very flighty but the strut change may help. I will get back to it in due course and report.
Ok so after the strut change and a new turn fin, I made one from springsteel (being a springmaker can be useful), I got a run in on Saturday. We were doing two lap sprints, and with an M445 it was running great. I did a time about 1.5 secs under the one I set with my whip 20, however the water was very rough for a boat this size with 3-4" chop on the left hand end of the oval and I had to button off a lot. The right hand end was calmer so wot for that end and it turned awesome at full speed and was stable. I can't wait to get it out again on flat water and try a 447 on it!
