Paint help
  • Santig
    • Nov 2019
    • 79
    Paint help
    Morning gents. I'm in the process of painting my Cheetah hull. There was a slight runoff on two small sections. The paint is Krylon satin bright white. I wet sanded the areas smooth but the satin lost its shine in those areas. Can I go ahead and continue with striping and adding colors then clear or do I need to repaint those areas?
    Thank you all!
  • mxrb18
    • Jul 2019
    • 53
    what grit did you wet-sand up to? If you wet sand up to 800 or 1000 I would say go for it and get the striping and clear done shouldnt hurt
    • Santig
      • Nov 2019
      • 79
      I wet sanded lightly with 800 grit. My concern is the base lost the shine in those areas. Thank you for replying sir!
      • mxrb18
        • Jul 2019
        • 53
        If you’re concerned I would wipe it down real good with some degreaser and then lightly mist that spot again to give it that shine back
        • Santig
          • Nov 2019
          • 79
          Yeah, think I'll do that. Thank you 😊
          • Santig
            • Nov 2019
            • 79
            Here she is. Decided to try a color shift paint called purple sunset. This is my first time painting a boat and a last minute idea on the masking tape caused a small blob in the front corners but I can fix it. What yall think? She is almost ready for window, decals and clear.
            • Santig
              • Nov 2019
              • 79
              I'm in need of some advice. I painted the above using krylon fusion in satin bright white and used the testors color shift to make the stripe. According to Testors/dustoleum its a oil based product. Should I use the krylon triple thick glaze and clear on it, a rustoleum clear or another brand? I just dont want the paint to wrinkle. Im going on a trip and letting it cure for a week or so before applying the clear etc.
              • Santig
                • Nov 2019
                • 79
                Oh, here she is with the new decals on before I clear in a week.
                • 30nitro
                  • Feb 2018
                  • 330
                  Well i would definitely use a clear that is recommended for the base color...if it's oil base you can't use a lacquer base clear...it will wrinkle.... Rustoleum...?
                  • Santig
                    • Nov 2019
                    • 79
                    Yeah, apparently rustoleum is oil based where the clear for krylon is lacquer
                    • 30nitro
                      • Feb 2018
                      • 330
                      Good luck with it !! Let us know how it turns out.. Happy Holiday's...
                      • Santig
                        • Nov 2019
                        • 79
                        Happy Holidays to you all and wilco!
                        • Santig
                          • Nov 2019
                          • 79
                          Here she is with decals, will clear her on monday.
                          • 30nitro
                            • Feb 2018
                            • 330
                            Lookin good !!!
                              • 7673
                              Looks fabulous. Which clear are you going with? Just a suggestion, DO NOT USE UPOL CLEAR#1!!! Well... not without testing on the Testors paint. Many have used the 2k clear (I can’t remember manufacturers). It is a two part spray. I have two cans of it but haven’t used it yet.
