I'll do the best I can to post the build as she slowly comes along this winter. As of right now all I have is the hull. Technically its on the way coming from Germany to the States. This will be the Largest boat in my fleet. My other 13 are all around 30-34 inches. As the title reads I'm looking to make this a twin and need a little help from you guys with the electronics and props. As it progresses I'll reach back out for proper placement of struts, mounts, ect. Right now I'm working on getting my parts order placed for electronics and hardware.
So to start here are my thoughts for motors, props and batteries:
A pair of TP5650's 1400kv 6 pole can size 55X70 max volts 42, max amps 200, max rpm 55k
2 ZTW ESC's 300A
2 CNC 52mm high pitch 3 BLD's
8s-10s each motor. lipos 6500Mah 90c (currently have a ton of 3s and 4s. I'll pick up a few more 6s packs.)
On 8s this should be around 34k loaded RPM, 10s SAW passes 42.5k RPM
By the OSE calculator this should get me where I want to be and then some.
The bulk of my current fleet all run on 6s, 4082's, 1900kv to 2075kv, 70-85mph. (I want this boat to meet and possibly exceed the rest of my fleets standard)
All thoughts and comments welcome. Am I on the right track?
Thank you all in advance!
2 ZTW ESC's 300A
