carbon fiber reinforcement
  • tjj atx
    • Mar 2018
    • 109
    What weight of carbon fiber fabric should I use to reinforce a fiberglass hull?
  • fweasel
    master of some
    • Jul 2016
    • 4286
    I use a standard 2x2 weave 3K cloth. It still conforms to the corners well enough. I've used multiple layers on particularly flimsy sections of some hulls, or in problem spots like seams.
    Vac-U-Tug Jr (13mph)
    • tjj atx
      • Mar 2018
      • 109
      Thank you sir. That will help me out, any particular suppliers you prefer?
      • REDLINE1
        • Jul 2016
        • 199
        This what I used
        https://www.amazon.com/Twill-Carbon-...gateway&sr=8-6
        • martin
          • 2887
          You can get plain weave carbon cloth or twill, the twill is easier to use on compound curves & into corners etc. Personally i prefer twill as it stays flatter easier in these areas, plain weave can lift in these areas once wetted out with resin before the resin cures.
          • fweasel
            master of some
            • Jul 2016
            • 4286
            Yep, what I use is a twill weave. I misspoke when I said plain.
            • tjj atx
              • Mar 2018
              • 109
              Thanks guys. Greatly appreciated. I like that combo kit with the resin. Would Gflex epoxy work as well or should I go with a resin and hardener intended for carbon fiber?
              • martin
                • 2887
                No you want a laminating type resin & hardener like west 105 resin + the appropriate hardener to use on carbon or glass cloth ( other makes available ). Gflex is a thicker adhesive for bonding.
                • tjj atx
                  • Mar 2018
                  • 109
                  Thanks again guys. All your responses have been more than helpful.
