What's the best way to cut my flex shaft and what if anything should I do to the end once it's cut?
Cutting a flex shaft?
Tags: None
Tell what I have done and haven't had a problem so far, heat the area that needs to be cut to red hot, while it's still hot solder near the area that needs to be cut and the solder penetrates, cut with dremal cutoff tool at length, then after it cools down chamfer the end a bit so that it slips in collet easy, I check solder on the ends after chamfering just to make sure its a good soldering joint (if not re-solder the end) -
I wrap the area that needs to be cut with masking tape and mark the cut with a sharpie. I cut the cable with a thin dremel cutoff wheel, remove the tape, then put a light bevel on the blunt end with my bench grinder. I do not solder my cut ends and it has never been an issue on my boats.Vac-U-Tug Jr (13mph)Comment
I haven’t soldered a cut flex cable in almost two decades....never had one unravel either. But, I do use collets exclusively, no set screw couplers for me. I use a cut off wheel to shorten cables, and also bevel the cut edges slightly. I never leave a cable in the stuffing tube after a day of running; I wipe it off and place it inside the hull for storage.
Some downsides of soldering flex cables:
- most folks can’t solder well, so it’s a bad job
- overheating the cable when trying to solder will damage the cable, shortening its life
- the flux required for a good solder job must be removed or it will corrode the cable inner strands, shortening its life
- excess solder may make the cable too large to fit in a collet
YMMV
Bringing up an old thread. I have cut quite a few flexshafts. My preferred method is to cut the shaft using a Dremel thin cutoff wheel. Using a portable gas flame (used by chefs/cooks) in the kitchen for browning broule, etc. I then solder the cut end and chamfer the edge. Ensure flux used is thoroughly rinsed off.Comment
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414Comment
The day after tomorrow I have my first cut (tomorrow I epoxy in the motor and stuffing tube). Seems there are two school of thoughts; to solder or not to solder... THAT is THE question! Considering folks have not had problems with flex cables unwraping and that I will use a collet, I think I am going with the no solder school of thought. Besides, I can always solder later!Comment
Well, flex cable is cut and set (and stuffing tube is bent and glued in)! Everything lined up VERY nicely! No binding or extraordinary friction or anything. Did a dry test with the motor (lowest possible speed and just for a second or 2, as I have not lubed the tube yet!), and runs just fine. Could have cut the flex shaft maybe 1/8 to 1/16 longer, but I think it will work just fine as it is. But I wanted to post some pics in case you (more experienced) guys see something I don't.
Top part of stuffing tube.
Bottom side
And here you can see the angle of the shaft/prop.
EDIT: Ignore the tubing, as I am waiting for more to arrive to run it through all the right places. Only the ones with tie wraps are final.Comment
I prefer to leave more room between the end of the stuffing tube and motor collet. Gives you more room to wipe the grease off the flex cable before it goes in the collet. Nothing much you can do about that now unless your collet can move further up on the motor shaft. I'd also eliminate the motor mount from your cooling route. It's an unnecessary restriction and doesn't really do anything for motor cooling.Vac-U-Tug Jr (13mph)Comment
I figured as much with the collet spacing, but I kind of painted myself into a corner there. I cannot move the motor forward because of balance, and I cannot make the angle shallower because of clearance with the canopy and hull... but I completely understand your point here!
As for the motor mount cooling, will do so. Wish I knew that before I bought the fancy mount with cooling!Comment
I haven?t soldered a cut flex cable in almost two decades....never had one unravel either. But, I do use collets exclusively, no set screw couplers for me. I use a cut off wheel to shorten cables, and also bevel the cut edges slightly. I never leave a cable in the stuffing tube after a day of running; I wipe it off and place it inside the hull for storage.
- most folks can?t solder well, so it?s a bad job
YMMV
.Comment
[ATTACH=CONFIG]168755[/ATTACH]
[ATTACH=CONFIG]168756[/ATTACH]
Bottom side
[ATTACH=CONFIG]168757[/ATTACH]
