Twin P Cat +100KV Outside Motor?
  • Mike W
    • May 2018
    • 348
    I can't say this idea has not crossed my mind but a seller screw-up placed it right in my lap.
    I picked up a wrecked X2 hull since I've been wanting one for a while seeing how well they run, but wasn't prepared to fork over for RTR. I love the build too much and the hull alone is not available.
    So I ordered a pair of elcheapo ZTW 3674s for it and after installing found I had one 2150 and one 2050KV. Emailed seller about that but am now wondering if its worth a try running the +100KV on the outside/left.
    I'm not willing to do the math on the RPM difference though the turn but hope it might be more than 100KV on 4S and this would "split the difference" on turning/straight performance.
    Any thoughts? Anybody try this or slightly different props on a circuit twin?
    Otto RC Marine
    • 7673
    This could be interesting. Any chance you could check the KV on them? That is rarley spot on anyway.
    • fweasel
      master of some
      • Jul 2016
      • 4286
      So what is the plan in the straights, more rudder input? Certainly an interesting project. Starting with the busted hull definitely keeps the investment down
      Vac-U-Tug Jr (13mph)
      • dasboata
        • Dec 2010
        • 3152
        Actually the hi rpm motor should go on the right looking from the back pushing the boat left to counter the prop walk
        • TRUCKPULL
          • 2969
          Not if he uses counter rotating props.
          Larry
          • dasboata
            • Dec 2010
            • 3152
            Larry
            don't matter,, thrust is thrust no matter what direction it's turning boats generally pull to the right
            • Mike W
              • May 2018
              • 348
              I’ll test it out thanks!
              Otto RC Marine
