That nose piece turned out to be about 11/16" on my boat which of course doesn't exist in the store. It will be 3/4" on most peoples boats though.
The Black Pearl LSH Spec Hydro 2019
I checked the model, it was designed for a 3/4" halfround stock at the nose. I allowed a little bit of xtra for sanding and blending into the upper and lower sheeting.
Jay - she meets all the rules including transom width ratio. Designed in the spirit of a sport hydro with some innovations!Comment
Pete, please let me know when a kit will be available. I’m looking forward ro building a pearl with these mods.Comment
Hi Pete, I know all your measurements will be correct. kinda like my FE30,looks like a sport hydro from the top , a little different from the bottom.
I built the P version with a friend who lost his wife last year and it has been great therapy for him. Its not perfect ( not with my wood building skills) but with a little filler and paint it will look great at 5' if you squint! We've had a lot of laughs building it.
You can put me down for a limited version once you get all the bugs worked out. Next winters build!
Cheers, Jay,Comment
No secrets! Just trying to apply a little dynamics. A hydro requires pressure underneath to support the weight. The pressure is built by trapping air. If you trap too much air and the pressure is too high, the boat blows over. That's why there are speed limits to hulls. Back when we were running NiCad's, we never reached the speed limits so we wanted to trap as much air as possible. Nowadays, the technology is much better and boats are considerably faster, so we need to trap less air to build the same pressure to hold the boat up. The idea behind the sponson vents is to allow the air to escape or 'bleed out'.Comment
Cheers, Jay,Comment
Hope to make it in June Pete, sorry no pics. We just drilled for hard ware. going to put the skins on the deck. sand/fill sand and paint before the thaw. Its going to be green and yellow, Jon has a big collection of John Deere stuff !!
Cheers, Jay.Comment
A little more work done. The nose contour was designed to fit the UL-1. I cut about an inch off the edge of the hatch. Other than that, it fits perfectly. Just need to add the 3/4" half-round to the front. I also fabricated the motor mount out of aluminum and started mocking up the stuffing tube.Attached FilesComment
I had no 1/4 tubing in the shop. How the heck does that happen
.20190324_212219.jpgNoisy personComment
