TFL Stinger outdrive rigging dumb questions.
  • davelc56@gmail.com
    Capt. Dave
    • Oct 2018
    • 28
    Does anyone have a side view drawing that shows exactly how the stuffing tube mates with the drive?
    I question how far the brass tube with nylon liner is supposed to go into the leading opening of the drive piece and how do you trim the drive angle without relocating the tube exit hole, slightly up or down? Or is there supposed to be a gap in the tube to allow for trim? If so, how do you keep the short tube in the drive? How much gap?
    What stops the nylon liner from turning in the tube? If it turns, the grease hole will not line up.
    Stupid questions from a beginner, sorry.
  • Beaux
    • Dec 2015
    • 550
    Go to the advance search in the upper right corner and type in
    Delta Force 35 in. Pirate from Ose mine might come up. Anyway
    you should be able to get some help there. Have Fun.
    • Beaux
      • Dec 2015
      • 550
      I used a big o ring in mine, I finally siliconed it in there the fitting does not turn now.
