Pro Boat Shockwave V26
  • creekrunner
    • Dec 2017
    • 51
    Pro Boat V26 Has anyone converted this to an outboard setup ??........seems narrow and the mounting an outboard might make the rear top heavy..........looks to be an easy retrofit. ( I have a new hull).......but question the results ??
  • creekrunner
    • Dec 2017
    • 51
    Nobody? Opinions ? I like outboard setups......that's it..........
    • 30nitro
      • Feb 2018
      • 330
      There are outboard that would fit and work...but I think you might be disappointed in the handling and speed......
      • creekrunner
        • Dec 2017
        • 51
        beam to narrow ?
        • 30nitro
          • Feb 2018
          • 330
          Yes for one....the hull is a bit too small to handle the weight aft.... I have tried outboard on smaller hulls...but.... I have a couple larger hulls that handle an outboard well.... Not to say you couldn't try it ..
          • creekrunner
            • Dec 2017
            • 51
            thanks........I'll give it a go....time will tell.......
            • creekrunner
              • Dec 2017
              • 51
              Working on it.......
              • Bp9145
                • Jan 2016
                • 1466
                Hey Buzz, that actually looks really nice with that monster outboard motor. . in a real boat it actually works but with rc boats it's a bit different as the power and weight ratio could cause some problems. I actually had three of these( two older ones and the newer green one like the one you have)and like you I was curios on putting an outboard motor. So I did convert one of them to an outboard setup. Oh, I forgot to add, I was worried that the transom might be weak so I glassed it with several sheets and I did the seams as well while I was at it. Then I filled all the open areas, especially in the open pockets in the rear of the boat, with pool noodles to keep it from sinking too much. I used a T180A esc and tried a couple of motors, I think they were a 3660 and a 3674 that I used to power it up. . Then when I ran it I had the batteries, two 3S 5000mah in parallel, up front towards the bow. I tried with higher voltages and the results varied with different voltages and different props. It ran pretty good but I didn't have a gps unit at that time but I would say at least 40mph. I wish I still had it so I could send you pics. Just make sure you don't use the stock 30A esc. Put at least a 120A or higher where if you want to run it as high as 6S you can. But make sure your motor of choice will handle 6S or higher as well. good luck and keep us informed and a video of it running
                • fweasel
                  master of some
                  • Jul 2016
                  • 4286
                  Ha, cool graphics layout. Fits the upcoming holiday.
                  Vac-U-Tug Jr (13mph)
                  • creekrunner
                    • Dec 2017
                    • 51
                    Thanks for all comments.....the color directed me into going the "Grinch" mode route.........I will use a 4000 3s Graphene .....positioned to give me a balance point about 40-45% up from the stern.... I don't really care too much about speed, just want decent as possible handling and run time. Motor height, tilt angle and trim tabs should(?) enable this. ESC is 90A. It'll be spring before testing as the local ponds are already skimmed over. (Vermont). I just like the build aspect of this hobby and seldom "color within the lines". As long as they look decent.....on the shelf if nothing else...ha!
                    • 30nitro
                      • Feb 2018
                      • 330
                      Love the hull graphics...very cool..!!
