Aluminium offshore powerboat build
  • nospig
    • Apr 2018
    • 3
    Hi all, just wanted to share a build video i made. www.youtube.com/watch?v=r6_DqBTy35s May be helpful or inspire with your build.
  • Peter A
    • Sep 2012
    • 1486
    Interesting build. Where are you in NZ? The pond you are running on is a nice one!
    You could perhaps move the CG back to get the front up a bit, I doubt you will manage to blow it over easily.
    • nospig
      • Apr 2018
      • 3
      Thanks. I was going to try a few things like that to see how it effects performance. The 3 runs you saw are the only runs so far.
      • hughb
        • Jul 2016
        • 152
        Very nice and original! How does the weight compare to a similar sized fibreglass boat?
        • Luck as a Constant
          Make Total Destroy
          • Mar 2014
          • 1952
          Very cool man... ����
          • nospig
            • Apr 2018
            • 3
            I'm sure its a bit heavier than a carbon or grp hull depending on the thickness as 2mm alloy sheet weighs about 46% more than 2mm carbon sheet. Will post the weight once i weigh it.
