This thread goes hand in hand with the Dual Vortex Hydro build. There is a bit of info for this particular procedure, so I created a new thread. The purpose of this work is to provide a definitive seal at the end of the strut that accomplished the following:
1) Doesn't let water into the Stuffing Tube/Strut Assembly
2) Doesn't let grease and lubricants out
3) Keeps drag of the seal assembly to a minimum
You will need a good drill press or mill. I have a drill press. You also need a Machinist's Vice, as pictured. You will be machining into the back of the strut a 5/16" counter bore, to a depth of 0.150". I have had very good success using the Speed Master Struts, but I've also been able to do this mod on a stock UL-1 strut. You need at least an outside diameter of 0.350" to leave enough meat to make it reliable. I also install a graphite thrust washer, available from OSE. Finally, there is a retainer clip that is pressed into the back of the strut to keep it all together. This is a modified #10 split, helical lock washer, Medium thickness. I have this broken down in its steps, in order.. Note that the C-Bore tool needs a Pilot Tool inserted in the center hole of the C-Bore tool. The part number is P1873. The pilot should be set so that the face of the pilot stands 0.25" from the face of the C-Bore tool, using the set screw provided. Here are pics of the parts needed:
