New C5000 build from scratch
  • dazzler
    • Feb 2011
    • 52
    Hello all,
    A couple of months ago I posted a topic on this forum because I was all confused about possible motor/ESC combinations for my latest project. (that topic can be found here: https://forums.offshoreelectrics.com...e-Current-Draw)
    Anyway, somewhere in that topic I was asked by another forum member if I would take pictures of the build and share it here on the forum. So, here we go.
    For starters, I live in Belgium (Europe) so forgive me for some grammatical errors I will possibly make in this build log, because english in not my native language. Other then that, I hope you enjoy my pictures as much as I enjoy my build. Oh btw, I'm a slow builder, the pictures I will post today are work done over the last 12 months !!
  • dazzler
    • Feb 2011
    • 52
    So welcome all to my build log of the scratch build C5000 I'm currently doing.
    It all started about a year ago. A friend of mine who came over for dinner was talking about some offshore races he had seen while he lived/worked in Australia a few year earlier. When I showed him my first cat (a wood build 36" simple catamaran model) he almost immediately asked me if I was willing to build one for him as well.
    As it happens to be, I had some plans of a C5000 laying around (I believe they where once posted on this forum as well) which I had always wanted to build anyway, so I quickly agreed to his proposal, and decided I wanted to build at least 2 boats: one for my friend, but off course also one for myself.
    Building 2 boats also meant that I would be doing this build a little different... I did not want to build 2 separate wood boats covered with a layer of fiberglass, but instead I decided to build a master plug which would allow me to create a mold, so that I could in turn create full fiberglass (or carbon) hulls.
    First step was to check the digital drawings I had, make sure they were the right scale for me, and have them lasercut for me.
    Here are all the lasercut parts for this project, allowing me the build the plug:
    First step was to glue the long pieces together. I think it's called keel frame or something? Anyway, those were made up of 3 parts which had to be glued on top of each other. I used a long aluminum level and some scrape wood material to clamp them together and make sure they were perfectly straight.
    • dazzler
      • Feb 2011
      • 52
      After this, I trail fitted all the frames without using any glue, to make sure everything would fit:
      • dazzler
        • Feb 2011
        • 52
        In order to build a perfectly straight hull, I cut a piece of MDF board to the exact width of the tunnel, so that I could clamp both keel halves against this board. This will assure a straight and aligned placement of all the frames:
        • dazzler
          • Feb 2011
          • 52
          With both keel parts clamped together, I started to glue all the frames in place.
          • dazzler
            • Feb 2011
            • 52
            Then I glued the top deck in place, while everything was still clamped together to the MDF board. That way, the hull would not warp are get deformed while putting the deck on.
            Then I turned things upside down, to glue some 1mm airplane ply on the bottom of the sponsons:
            I also glued the bottom of the aft part in place:
            • dazzler
              • Feb 2011
              • 52
              After this, I also covered all other "open" areas of the hull. Sides, front, rear, tunnel bottom etc....
              • dazzler
                • Feb 2011
                • 52
                With the hull completely covered, the next step was to add a layer or 2 with fiberglass cloth and epoxy resin. This does not only give added strength, but also allows for smooth finishing used polyester putty (and a lot of sanding off course)
                And finally the hull already covered with a first (of many!) layer of polyester putty:
                • dazzler
                  • Feb 2011
                  • 52
                  In the meantime, I also started to construction of the canopy.
                  First a created a rough shape using some basic frames:
                  Then I used some small balsa beams to create a basic canopy shape:
                  After that I filled the entire thing with PU Foam:
                  Then I cut away all excess PU, and sanded in shape:
                  And finally, I applied a very generous amount of polyester putty:
                  • dazzler
                    • Feb 2011
                    • 52
                    Then, after sanding, this is the result:
                    I also put on a first layer of primer to see what imperfections are still left:
                    Next step I glued the canopy in place on the hull, and determined where I should cut the opening for the hatch.
                    • dazzler
                      • Feb 2011
                      • 52
                      Here is the canopy and hatch removed from the hull. I added some balsa beams around for added strength, and also that I could finish the sides of the hatch opening. Again I added some putty to create a smooth transition from the canopy to the hatch, and finish of the sides.
                      Then I fitted some thin plastic spacers around the hatch, and inserted it into the hull opening. The plastic serves as a way to keep a proper distance between the hatch opening and the hatch cover, and keep both perfectly aligned. I then glued some airplane ply against the hull opening which will become the edge of the hatch opening.
                      • dazzler
                        • Feb 2011
                        • 52
                        Then I sanded the ply flush with the deck, and inserted some MDF boards in the opening. These will later serve as a flange for the mold.
                        Fitting the hatch into place (without and with spray putty on below pictures)
                        • dazzler
                          • Feb 2011
                          • 52
                          With the hatch/canopy finished, I put everything an an MDF board, to that I will have flanges sticking around my hatch. These will serve for the creation of the mold.
                          I also put a primer and paint coat on it.
                          • dazzler
                            • Feb 2011
                            • 52
                            By this time, I already bought some hardware, so that I could trail fit some of those parts. Would want to end up with a full fiberglass or carbon hull only to find out that neither the rudder or driveshafts would fit...
                            Trail fitting the rudder and shafts:
                            In the end I wasn't happy with the "tail" on my hull (rudder support part) because it didn't align with the mounting bracket of the rudder. So I modified this tail to align is with the rudder bracket.
                            • dazzler
                              • Feb 2011
                              • 52
                              Because I will be making a mold later, which will be a 2-part mold, I need somehow be able to "split" the hull in 2 parts. This is done by adding a flange around the hull which serves as a divider between the upper and lower half of the hull. I've already started the creation of this divider.
                              First, I added some rudimentary cut pieces of particle board on a building board. On top of those particle board pieces a applied a very generous amount of silicone, topped of with a piece of plastic cut from a waste bag (to keep the hull from being permanently glued to the board...)
                              Next I cut some wood pieces with the required height to position the flange/divider on the correct position
