Hobbyking Osprey build
  • Old School
    • Aug 2017
    • 686
    I have temporarily installed the motor mounting plus some of the transom equipment. The Osprey, due not having a ride pad on the hull underside, apparently is known to be a little skittish on straight running. Following the "advice" of an experienced modeller I have fitted the stuffing tube, raising it approximately 3 mm from stock. This should settle the hull better and hopefully improve directional stability.
    From images and information online it seems that Hobbyking mount the stinger too low with one example seen the stinger tube sat almost 3 mm below the chine. The owner reported issues getting up on plane.
    • Old School
      • Aug 2017
      • 686
      The additional carbon fibre battery mounts arrived today so have been installed. The image shows the alternate battery locations for the 2 off 6s batteries in parallel.
      • Old School
        • Aug 2017
        • 686
        Some progress. Usual delays like other boat projects plus long lead times for deliveries. Anyhow, shaft installed. Structurally complete just awaiting the Swordfish ESC so that I can determine placement plus wiring. I hope to mount the ESC on the plate above the motor as I would like to keep the forward located battery trays available for battery experimentation for CoG. I have mounted the UBEC as far forward as I can to minimise interference with reception.
        The prop is an X452 balanced and lightly sharpened. This will be a starting point once the hull gets some runtime. Batteries will be parallel 6s 65C giving me about 8000 mah.
        • hughb
          • Jul 2016
          • 152
          Looking good. That motor looks huge!
          • Beaux
            • Dec 2015
            • 550
            Nice, those stingers are good I have several boats with them.
            • Old School
              • Aug 2017
              • 686
              Many thanks
              • Aleksey72
                • Jan 2014
                • 19
                • Aleksey72
                  • Jan 2014
                  • 19
                  #23
                  My osprey build:)
                  • Aleksey72
                    • Jan 2014
                    • 19
                    #24
                    • Aleksey72
                      • Jan 2014
                      • 19
                      #25
                      • Aleksey72
                        • Jan 2014
                        • 19
                        #26
                        • Old School
                          • Aug 2017
                          • 686
                          #27
                          Excellent build, very impressed. The kevlar will make for a solid build. What is the bearing you have please between the stuffing tube support and the collet? What size motor did you fit?
                          • Aleksey72
                            • Jan 2014
                            • 19
                            #28
                            Handmade hull, carbon Kevlar.
                            • Aleksey72
                              • Jan 2014
                              • 19
                              #29
                              Motor 5684,1000 kv, Esc Flier-300a.
                              • Aleksey72
                                • Jan 2014
                                • 19
                                #30
                                Flexshaft-6.35,propshaft-3/16,propeller test-448”-105 km/h.
