What Paint
  • Tom G
    • Aug 2017
    • 57
    What Paint
    Will today's Automotive Ie: (water-born) based paints stand up to nitro fuels unlike enamel
    Or should I stick with Lacquer on a fiberglass hull
    Looking at products from https://touchupdirect.com/
    TNX Tom G
  • NativePaul
    Greased Weasel
    • 2760
    You may get an answer as I know some guys here are multi discipline, but this is a forum for fast electric boats. I am sure I wont be alone in having no idea as I don't have to deal with Nitro fuel. You may want to join Jim's Boat Dock which is more for IC boats.
    • CraigP
      • May 2017
      • 1464
      Well, it's a paint post, so I have to say paint is busting my balls like crazy right now! I'm getting crinkle, runs, the whole shot... I don't know when the hydro will get back out. Paint bums me out!
      • longballlumber
        • 3132
        TNX Tom G
        Tom,
        I use www.klasskote.com on both my nitro and FE boats. This paint is a 2 part epoxy paint. Although FE doesn't require the "nitro proof-ness"; the klass Kate stuff is some of the toughest stuff I have ever used. Several of my FE club members have used it and are very happy with the results. Attached is one of my nitro boats that I used klass kote
        • CraigP
          • May 2017
          • 1464
          I've been sitting here trying to remember a name of a paint.. That's it, KlassKote! The other was Imron, we used that on the full sized boats. Both are expoy paints. Tough stuff, but have to really let this stuff set up...
          • Tom G
            • Aug 2017
            • 57
            I run FE & Nitro class and was try to get some in info on the more modern and less toxic non solvent based paints that I could use on both FE and nitro 1/8 Unlimited boats
            • NativePaul
              Greased Weasel
              • 2760
              Cool welcome to the forum. I would still recommend that you join Jim's as well as this one though.
              Craig, you have to let typical paint set up too, crinkle in paint is normally caused by laying paint over other paint that is still curing, chemicals given off during the cure lift the paint above it. you need to either lay the coats very close in time so they are curing together, or wait for a full cure to apply the next colour which could be a couple of weeks depending on temperature. Runs are just laying down too much paint at one time.
              • CraigP
                • May 2017
                • 1464
                Yup... Patience is a virtue that apparently have not yet acquired when it comes to paint. It's hard to avoid runs shooting rattle cans. They spray heavy because they are made to cover larger surfaces. But runs aren't that hard to fix. I crinkled the cowl because I waited too long in between coats. It's been hotter than a pistol here in Tulsa, very difficult conditions! The day before the bottom crinkled very badly! Turns out the base white coat did not adhere to the primer well, and the top clear pulled it. This is enamel and waited 3 days in between, so I'm not sure what happened there... All I know is it's got to be sanded off and start again. So glad I got the DF29 Mono, at least I have something to run! I will avoid painting another hull, just run on the gel coat and decals. A buddy is going to let me use his small compressor and paint gun to try and get thru the bottom...
                • Beaux
                  • Dec 2015
                  • 550
                  Try using lacuer thinner the paint will wipe off. Been there done that . Sanding works but you usually go to far. Try the thinner , good luck.
