I'm currently building a rc mono and I plan to use a leopard 3674 2200kv motor on 6s and a 640 de tongued prop in it. Which one of the monohulls on OSE would you say is best if to use with this setup?
Go for a Pursuit on 4s. You could also go with a 4074 or 4082 size of 2000-2200 kv, or you can upgrade later. The prop you have should be ok, test and check temps as you go, also 442,445, 437/3 may work. It all depends on what you are wanting to achieve. The OSE Raider 150 esc will also be suitable or a T-180.
If you already have the 2200 then go 4s. There's no need for 6s on that motor. Amperage will be high (there's that heat). Heat is the devil with these things. On 4s you could probably get away with a Raider 150. They're priced right and you get world class OSE service. Great little ESC. The Seaking 180 has been a goto for many. I've run and abused those a ton. They've delivered power to setups for me that absolutely should not have worked. Down side is that there was a span where some of them were shutting down prematurely. I'm not sure anyone ever really figured the problem out. Also not sure if the supply chain has been cleared of the those units or not.
Pursuit is a killer boat. I have two.
Cyberstorm is stellar too. The Cyber might be a better boat. It's a solid debate.
A Delta 33 is easy to setup and almost identical to the first two on the bottom.
A Delta 29 will really scoot on that motor but they can be a hand full to drive. Super sensitive to center of gravity. If you're leading they're killer. If you're chasing you need to do a lot of throttle work. Fun to drive if you like to........drive. haha
