Genesis problem
  • Kram
    • Aug 2016
    • 48
    Genesis problem
    Hi.
    I am currently rebuilding my genesis with new
    3/16 stinger, but i wonder how you guys drill holes for the stingers in the transom? The drill is just to big in order to get it look nicee and straight. The problem is that the angle of the holes isnt right because of the drill. Please help me
    Thanks!
  • numse
    • Jan 2017
    • 7
    I used a Dremel.
    • Kram
      • Aug 2016
      • 48
      Thanks.. I bought a long 3,5 bore bit so i will try that first... Should i drill a bigge holde for the tubing so it can move a little? And then just use epoxy when its correct?
      Should the brass tube be some mm outside the hull when i moumt the stingers or just flush with the transom?
      • Bigford
        • Mar 2017
        • 72
        On my apparition the stuffing tube will seat it's self
        In the stinger. Hole in the hull is a little larger then the tube.
        As soon as I find motor mounts that will fit. I'll assemble
        Everything mark it and glass it all
        • Kram
          • Aug 2016
          • 48
          So you have the tube a little outside the hull?
          Another thing... is it normal that the flexshaft is hard to rotate without grease? Its 3/16 shaft and stinger
          • Bigford
            • Mar 2017
            • 72
            Yes just a touch larger so the shaft can line up
            With everything. Scuff the tubes so the epoxy
            Sticks to it.
            • Kram
              • Aug 2016
              • 48
              Thanks Bigford. Kinda new to this :P Gonna drill a little larger hole for the tube, make it few mm outside the hull and then glue the tube when the stinger is mounted and correct. What do you think of the other question i had?
                • 8012
                Are you using a Teflon liner?
                • Kram
                  • Aug 2016
                  • 48
                  I just tried to put the flex cable into the stinger without teflon line or tube
                  • Kram
                    • Aug 2016
                    • 48
                    I have: http://offshoreelectrics.com/proddet...?prod=ose-1190 and the reversed.. and http://offshoreelectrics.com/proddet...prod=ose-80108
                    • Kram
                      • Aug 2016
                      • 48
                      Clue anyone?
