What are the better grabbing collets to buy. The Princess factory one is really tight and still slips every now and then. Who makes a really good one 5mm motor shaft and .150 flex cable.
Best collet
I bought a few off ebay and they all wobbled causing the cable to smack the stuffing tube. I bought an Aeromarine and I really like it, and it has an insert so you can go up or down in cable size with the same coupler.
https://www.offshoreelectrics.com/pr...d=aero-couplerNEVER SATISFIED RACING
Fine Design 32 V-Hull 4082+6sComment
I've gone to H&M at rocket City Racing in FL. Steve sells the MBP which are a tad better than H&M.
China copied H&M couplers but used steel instead of high grade Aluminum.Nortavlag Bulc
Just get a couple from OSE. They will work fine in your boat and are inexpensive. They don't last forever but it helps to put a little antisieze/coppercoat or similar on the thread and always make sure they are done up firmly.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
BOPMPBC Open Mono, Open Electric Champion.Comment
https://www.offshoreelectrics.com/pr...d=aero-couplerComment
I also have the aeromarine 3 piece in my 32" rivercat. Its a nice collet I've never had to replace the brass insert but have only maybe 100 runs on it. I would probably buy the MBP over the 3 piece aeromarine.Comment
100 runs that is pretty good, being I can't even get one in without slipping. Why MBP over the Aeromarine? you can get two Aeromarines for the cost of one MBP is it really that much betterComment
Are you cleaning grease off the tip of the flex cable before it goes into the collet? That will make a collet slip every time. I'll pull the collet off my motors every once in a while and spray them out with brake cleaner. The MBP seems to be higher quality, and I like the clamp design rather than crappy grub screws that strip out. I've planned on trying one out just haven't needed it yet.Comment
