DYMotorshop 17" Carbon Mini-Mono Build
  • Darin Jordan
    • 8335
    Thought I'd post some pictures of a build I just completed for a friend of a DYMotorshop 17" Carbon Mini-Mono. He's supplying the power system and radio gear, so he just asked me to get the running gear worked out.
    Used various bits I had in spares boxes, and had to machine a few pieces myself, but I think it turned out pretty nicely.
    Power is going to be a 28mm motor setup for 3S running. Should be a fun little boat!
    Darin E. Jordan - Renton, WA
  • NativePaul
    Greased Weasel
    • 2760
    It looks good Darin. Those Plastic Octura 531s are garbage though, both floppy and fragile at the same time, if you need plastic change to a 4mm shaft and use a Graupner 2318 33 for about the same load with better performance and much better prop longgevity, or keep the drive and use a metal x432.
    Having said that 32mm is pretty big for a mini mono, if he hasn't bought the motor yet he may be better off upping the KV a little and stepping back to octura30mm / graupner 31mm for better handling.
    • Darin Jordan
      • 8335
      I'm amazed at how many people focus on that prop, when there is so much other beautiful work there to admire...
      • ray schrauwen
        • 9472
        You can actually drill through a Graupner prop with a 7/64" bit. The threaded 1/8" shaft will tightly thread into the plastic material like a nylock nut.
        Nortavlag Bulc
