Best epoxy to pour into bow?
  • fweasel
    master of some
    • Jul 2016
    • 4279
    I've read enough to know this is a good idea, but could not find specific epoxy types being used and it what quantities. Will a 30min epoxy like PT39 do the job? How much should I pour in? I was thinking somewhere between 3 and 6oz into a 36" mono hull.
    Vac-U-Tug Jr (13mph)
  • 785boats
    Wet Track Racing
    • Nov 2008
    • 3169
    When I've done it, l used epoxy laminating resin. But I also chop up some fiberglass mat & poke down in there too. Then give it a good prodding with a stick to get it well wetted.
    Makes it stronger & lighter than just epoxy.
    • Mxkid261
      • Jun 2015
      • 734
      I also use epoxy resin with a little chopped cloth stirred in. I put the bow of the boat in a bucket of cold water while it cures too, Ive had the sponson tips on cats kind of deform from the heat of the epoxy
      • fweasel
        master of some
        • Jul 2016
        • 4279
        Thanks, PT40 finishing resin it is. I've got plenty of carbon mat left over. When you say chop, just cut it into pieces with a scissors? Is my end goal medium stands or tiny little fibers? And what's a reasonable thickness/height of the pour into the hull?
        • Mxkid261
          • Jun 2015
          • 734
          Check out post #3 in Travis mono thread, this is how I do it. I'm sure others are a little more accurate Lol I just cut up a little cloth or carbon with my shears like he does and mix it in. I would say 4 oz would be enough, this on your voracity hull? Looks like he mixed at least that much for his kbb mono, but that was for the seams. Not sure if he put any in the bow but I'm sure he did
          http://forums.offshoreelectrics.com/...Doo-mono-build
          • TheShaughnessy
            • 1431
            I did my geico like this recently, I dumped in a one pump mix of west systems with the fast hardener which is 25 grams and I put 8 g of chopped up carbon fibers, I had cloth so i folded it about 6 times, or even just roll it up and then cut small sections and let them fall into a cup, it can get itchy quick so i'd suggest covering up. I did that in each tip of a geico and spread a little bit into the section between the two tips. Adds weight but I feel sorry for anybody that crosses me up this race season because those tips are SOLID.
            I dont see why pt40 wouldn't work, i'd warm it a bit if you are in a cooler climate, it gets fairly viscous when cold and doesn't flow nearly as well.
            • Shooter
              Team Mojo
              • Jun 2009
              • 2558
              I put 3/4 to 1oz in each sponson tip of all my boats. West Systems w/206 slow hardener (slower cure avoids the heat problems mentioned by Mxkid above).
              TheShaughnessy - Definitely solid!! I went right THROUGH another boat a few years ago and I came out smelling like a rose! Not even a scratch. Who says wood boats aren't strong???!!
              • fweasel
                master of some
                • Jul 2016
                • 4279
                Okay, thanks for everyone's input. I mixed up 4oz of Zap PT40 finishing resin and cut up a 2" x 1" piece of 2x2 carbon mat. I warmed the resin first on top of an amplifier in the rack next to my bench and it poured nicely into the mixing cup, but as soon as I started mixing it with the carbon, it thickened up. It was still workable, but next time I will heat it even more before mixing. poured the entire cup into the bow of my Voracity and propped the hull up in place. I was on a roll, so I mixed up three more 1oz cups for my Zelos. I poured one in each sponson tip and the third over the deck seam between the two tips. The thickness actually helped me to keep the pour on the deck seam from draining down into the tips. Propped up that hull and I'm done for the night.
                • ray schrauwen
                  • 9471
                  That was funny... for you. lol...
                  Nortavlag Bulc
                  • Tamelesstgr
                    • Jun 2014
                    • 1516
                    Get'R'Done
                    NEVER SATISFIED RACING
                    Fine Design 32 V-Hull 4082+6s
                    • fweasel
                      master of some
                      • Jul 2016
                      • 4279
                      Originally posted by Tamelesstgr
                      Get'R'Done
                      All this warm weather has me convinced I need to be ready for the water sooner than later!
                      • Mxkid261
                        • Jun 2015
                        • 734
                        Ya suppose to be 50 around here this weekend. I'm ready for the ice to melt
                        • Darin Jordan
                          • 8335
                          BE CAREFUL pouring in TOO Much epoxy all at once. It gets REALLY HOT when it cures, especially in large quantities, and will cause the hull to deform some wherever it's touching.
                          Ask me how I know...
                          Darin E. Jordan - Renton, WA
                          • Mxkid261
                            • Jun 2015
                            • 734
                            Ya I found out the hard way too lol a bucket of water seems to help
