Aeromarine Vector 10s
  • Moonie
    • Jan 2014
    • 325
    It's going to run goog!
    Gold Spilo
  • fweasel
    master of some
    • Jul 2016
    • 4286
    Does goog mean fast?
    Vac-U-Tug Jr (13mph)
    • Moonie
      • Jan 2014
      • 325
      I'll show you when it's done.
      Gold Spilo
      • Moonie
        • Jan 2014
        • 325
        Gold Spilo
        • Moonie
          • Jan 2014
          • 325
          IMG_1302.jpgIMG_1301.jpgIMG_1304.jpgvideo soon to come.
          Gold Spilo
          • Dragon-Fly
            • Jan 2014
            • 7
            Hey Moonie,
            I'm running a Vector 45 too since 2014, with a TP5840s Motor on 6s and 8s. It took me a lot of work/time getting the boat real fast. Now it is running, GPS measured, 120 km/h at 6s and 140 km/h at 8s! I built it just for SAW use, so the turning ability is a bit poor, but running straight away it is very stable, when properly balanced (depends on CG, strut angle and prop choice).
            I am very exited how your setup will perform, let us know.
            Arnold
            • Moonie
              • Jan 2014
              • 325
              Hey Arnold
              Dang your Vector is cooking! I don't think my Vector will ever go that fast sorry bro I'm along ways from them speeds. This Vector I have use to have one of them slobbering gas motors in it. Rite now I have this Vector in race trim with speeds around mid 60s. We have a model boaters club with tons of gas monos. I wanted to show my fellow club members what a T mono is about. My Vector will run over 20min on one lipo charge. Isn't that crazy? What esc are you useing Arnold?
              Gold Spilo
              • Dragon-Fly
                • Jan 2014
                • 7
                Hey Moonie,
                Sorry, I wasn't at home for the last ten days. I am using a MBP 8s/250A esc (no longer available). Measured motor current has been 300a+ for a short time. My running time is less then 2 minutes using a 6s or 8s lipo with 5000mAh/1p 65c based to our SAW rules! With a moderate setup and more lipo capacity it should be possible to make longer runs. I would like to have the Vector 45 built with carbon (CFK) for more strength of the hull when blown off and hitting the water again. My hull cracked once after a 20 meter flight.
                • Moonie
                  • Jan 2014
                  • 325
                  Originally posted by Dragon-Fly
                  Hey Moonie,
                  The Vector pictured was split in three. You can tell now. I just got a 400amp esc I've been tying out I think I'm close to 70mph now. There a lot left on the esc and motor. The batteries are taking on some heat now.
                  Gold Spilo
                  • Moonie
                    • Jan 2014
                    • 325
                    Here is a video before the prop change and new 400amp esc.
                    Gold Spilo
                    • Moonie
                      • Jan 2014
                      • 325
                      Hey Moonie,
                      I got this neu 2230 1y. I was going to do one more Vector. What would you use it in Arnold? Do you know a better for speed?
                      Gold Spilo
                      • Dragon-Fly
                        • Jan 2014
                        • 7
                        The vector is running very well and stable in your video! Which props are you running? My best results have been with ABC 2315/17 two blade.
                        For your question, maybe a Virus, like Ralf Moser is running (fastest Mono till today!), could be a better hull for high speed application, I don't know the manufacture. But I think the Vector 45, with perfect setup, will come close to it.
                        Give it a try.
                        • Moonie
                          • Jan 2014
                          • 325
                          Give it a try.
                          I used a x455/3. X457/3 is what I use now I think it's the rite chose for what I do.
                          Gold Spilo
