Blizzard heat
  • Chop
    • Nov 2007
    • 504
    Blizzard heat
    I just purchased a Blizzard rigger (thanks Lakefront). Got it all set up the other night and finally put it in the water yesterday. This thing is a blast!!! Unfortunitly, I kept it out for about three minutes - should have checked it sooner, but I was having too much fun with it. Who would have though three minutes was too long (I do now)?
    Anyway, after bringing it in I checked the temps manually - forgot where I put my thermometer. Batt's were hot but not excessivily, motor was nearly cool, but the ESC had gotten so hot that some of the shrink wrap had melted near the battery and motor wires. There was water flowing through the cooling system - I could see it coming out as the boat went by.
    Electronics are: 6 S Fiegao motor w/cooling jacket, watercooled Baracuda 125 ESC and two Poly/RC 25C 4350mAh 2S1P lipos. All of this drives a 632 prop.
    I'm guessing that you guy's are going to tell me to prop down, but is there anything else contributing to the heat?
    There is a fine line between "hobby" and "mental illness."
  • Raydee
    • May 2007
    • 1603
    3 min at a time is about 2 min to long for a racing setup in a rigger. 6s is a hot motor on 2s Lipo. That setup is made for a 1-1.5 min race tops. If you want to have lots of runtime and keep it cool you are going to have to run a much lower KV motor. No it won't be fast but that is what you have to sacrafice for runtime. My 60+ MPH hulls only run for a minute and a half, sure the run time stinks but its a minute or so of pure bliss for me. If I want to run for longer times I can go to a lower KV motor, prop down and run at 40mph for 5 min but I would rather run it for 1 min and smile the whole time. Just find the happy medium and you should be able to run fast and still get better run time without burning things up.
    Team Liquid Dash
    • Chop
      • Nov 2007
      • 504
      Thanks Raydee. I didn't know that this boat was set up for just racing.
      At this point I will just keep the run times short.
      If I do want longer run times, and don't have any spare motors lying around, can I just prop down? If so, what size is suggested?
      • Raydee
        • May 2007
        • 1603
        Propping down some can help a little but nothing is better than the right motor for the hull and the type of running you want to achieve. On my Hydro's if I try to prop way down for long run time the hulls end up running to wet, not getting up and running like they would with the right size prop and actually run hot.
        Team Liquid Dash
        • AntronX
          • Jul 2008
          • 333
          So you ran two of those 2S packs in series? For 4S1P into controller? If so, see attached image.
          • Chop
            • Nov 2007
            • 504
            No, sorry. Two, 2s in parallel.
            • AntronX
              • Jul 2008
              • 333
              Oops, LOL. I was kinda getting amazed that barracuda 125 did not blow up in a nuclear mushroom cloud over the lake the moment you pulled the trigger... Ok, here is proper calc. The real world amps will be about 10 - 20 A higher than quoted. Man, those Castle controllers are tough.
              • highndry
                • Nov 2007
                • 664
                "shrink wrap had melted near the battery and motor wires". What connectors are you using?
                Boats don't win races, drivers do.
                • Chop
                  • Nov 2007
                  • 504
                  The shrink wrap is on the ESC. Melted at the solder joints on the ESC.
                  Connectors are 5.5 bullets all around, but they were unaffected.
                  • AntronX
                    • Jul 2008
                    • 333
                    Are you allowed to go double on volts? Connect your packs in series and get half the Kv motor, like 540-11S 3226Kv. Still the same power and speed, half the amps = one happy barracuda 125
                    • AntronX
                      • Jul 2008
                      • 333
                      Also, since you are running 900+ watts, why not Feigao XL instead of S ?
                      • Chop
                        • Nov 2007
                        • 504
                        The 6 S Fiegao came with the boat.
                        • AntronX
                          • Jul 2008
                          • 333
                          Post some pictures
                          • Chop
                            • Nov 2007
                            • 504
                            Originally posted by AntronX
                            Post some pictures
                            Pic's of what, the heat affected area on the ESC?
                            Here you go... The melted shrink wrap on the right, at the black & red connections.
                            • Chop
                              • Nov 2007
                              • 504
                              Took the boat out for a spin at lunchtime.
                              Ran the boat for 1 minute 10 seconds and brought it in to check temps:
                              Motor: 105 degrees F
                              ESC: 95 degrees
                              Batteries: 97 degrees
                              I GPS'ed the boat at 43.3 mph.
