The Black Pearl P Sport Hydro 2017
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    #211
    Good news. The lighter V8 version is running and turning well with the 1515-1Y motor. The CG is at the front edge of the turn fin (this is key!!). It also took 6oz of weight (placed at the CG) to keep it down in race water. Speeds are 62-65mph.
    Recall that I gave up on the big motor because it was just too fast. In order to keep it down as speeds approached 70mph, it would have required much more weight at the CG. The hull was at it's speed limitations IMO. Rather than just add more weight at the CG to keep it down, I'm trying to kill some more lift to increase the speed potential. On this experimental boat, I am reducing the AOA of the kick-up at the bottom. Some previous experiments with an air dam showed the boat to be much more predictable as it gave warning prior to a blow over (floated, rather than just snapped over).
    • TRUCKPULL
      • 2971
      #212
      Pete
      I got mine running at 70 with NO added weight.
      Larry
      • RandyatBBY
        • Sep 2007
        • 3915
        #213
        Ya know, I was having the same trouble with blow overs and after six months I found the strut had negative in it. It would cause the front to lift a little. Then the toque would pull the left a little more and over it went.
        Randy
        BBY Racing
        • Shooter
          Team Mojo
          • Jun 2009
          • 2558
          #214
          Originally posted by TRUCKPULL
          Pete
          Larry
          Cool!!!! Are you coming to the MI cup? I need to see this thing! How heavy is your boat? My heavier boats were fine, but the lighter ones are requiring some added weight at the CG. I'm really starting to believe that it's better to have the weight at the CG, especially for the turns.
          Oh man! That must have been a head shaker when you realized it! Definitely no negative here. My strut is dead nuts flat. Strangely enough, we did find that the rudder on the right side made it ride up the turn fin and blow off during slight left corrections. Moved it to the left side and eliminated that problem.
          • RandyatBBY
            • Sep 2007
            • 3915
            #215
            Ya it happen in a fall off the rack in the Tahoe. When I found it I thought how stupid. LOL
            Randy
            BBY Racing
            • TRUCKPULL
              • 2971
              #216
              Pete
              Yes I will be at the CUP.
              My boat is one of the first one I think.
              I did build it a little heaver with all the foam in the sponsons and down the sides.
              I run 2 degrees Positive (down at the rear) for the prop that I am running.
              Do you know if anyone makes a wedge to put behind the strut mount?
              I want to cock my strut about 2 degrees to the left.
              Right now at full speed the boat wants to turn slight right.
              I have set my trim slight left to compensate, but I would like to get it fully set up with the rudder straight.
              Larry
              • ray schrauwen
                • 9471
                #217
                When I build wood hydros I now add the same weight of aluminum to the Port size as I do on the starboard side for turn fin and mount.
                I use 3/16" or 1/4" thick stock and glue it to inside bottom of sponson. The weight is well distributed and you are adding structure to the boat not just dead weight.
                • CraigP
                  • May 2017
                  • 1464
                  #218
                  Truck pull, this is an old trick used in full sized boats for years to correct for turn fin drag and prop torque. I have seen more wedging on the rudder over the strut. I use a left side rudder to compensate prop torque and turn fin drag. It seems most modelers are seeing good results with changing the leading edge angle on the turn fin to correct steering problems. Moving the rudder under the boat can help too. Very small adjustments are advised, it's very easy to over correct. 1 degree movements should be used. Turn fin can also plant or let the right side sponson ride higher. Many options! The fun is finding out which works best on your hull and set up!
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2558
                    #219
                    Hi everyone. I'm pretty excited about this build (Version 8.7!). I moved the motor and servo forward significantly. The more I play with these things, the more I realize that most of the weight at the CG is best, especially for turning. You don't want weight scattered all over the boat. This new design should accomplish that.
                    I'm hoping to finish this to run in our September club race.
                    Oh, and congrats to MI CUP champ Kenny! Black Pearl wins P-Sport 3 years in a row!!!
                    • TRUCKPULL
                      • 2971
                      #220
                      Peter
                      I sent you an E-Mail about COG.
                      Larry
                      • robstercraws
                        • Apr 2017
                        • 157
                        #221
                        Where can you buy this kit?
                        • bozo586
                          • Aug 2009
                          • 344
                          #222
                          pete is on vacation now--send him a private message(shooter)--he will get in touch with you when he gets home.
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2558
                            #223
                            Congrats to Mike! IMPBA P-Sport 2-lap World Record!!
                            I'm going to cut more kits next week. If anyone wants one, send me a PM.
                            Thanks,
                            Pete
                            • bozo586
                              • Aug 2009
                              • 344
                              #224
                              pete ---pond cleanup sat. at 12--going to mr. b's after---if your there we can talk about another boat!!!!!
                              • T.S.Davis
                                • 6221
                                #225
                                John, let's talk him into a lighter smaller boat.
                                Noisy person
