2017 Build Log - Jet Chopper 30 Hull
  • Tamelesstgr
    • Jun 2014
    • 1516
    Slowly progressing, need to work on the following:
    Bend Stuffing Tube and make support
    Give final determination to COG and part placement
    Glue in motor mount and servo mount
    Fabricate battery tray
    Install flotation
    Work on hatch hold down
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    • Tamelesstgr
      • Jun 2014
      • 1516
      Time for some updates. I wanted to go with a removeable flotation, but pool noodles always seemed difficult to cut and fit well in the nose. A guy on Elite RC Boats on Facebook sells this flotation sheet for $25, so I gave it a whirl. Several layers tapered to a point and stuffed in the bow.
      • Tamelesstgr
        • Jun 2014
        • 1516
        Figuring out the COG I started positioning the motor mount and prepped the surfaces. I used JB Weld smeared on the bottom of the rails and a few drops of CA to tack it in place while the motor is in. I will remove the motor soon and finish applying epoxy on both sides of the mount. I think I will add small strips of CF cloth on the inside of the rails for a little extra security.
        • Tamelesstgr
          • Jun 2014
          • 1516
          I was struggling deciding how I wanted to mount the batteries, I settled on side by side trays for (2) 2s packs. I also added some slots in the middle of the tray so if I was to run my (1) 4s pack it could straddle the trays and the battery straps could still secure a single large pack.
          • Tamelesstgr
            • Jun 2014
            • 1516
            Tedious work cutting CF with a dremel, but it works. Added the standoffs and epoxied the trays to the hull.
            • Tamelesstgr
              • Jun 2014
              • 1516
              Epoxied the servo mount in place
              • Tamelesstgr
                • Jun 2014
                • 1516
                Not quite sure what to do with the warped hatch. Tape won't hold it flush, some said to secure it down to a board with nails over the edges of the hatch and heat the corners up with a hair dryer or heat gun. I do plan on adding M3 hatch screws like I did on my Deep-V, maybe that will be enough to hold everything in place.
                • Tamelesstgr
                  • Jun 2014
                  • 1516
                  I'm getting eager to drop this guy in the water soon, so I decided to put off paint till the warmer months. I slapped on the transom some CF vinyl and then re-installed all the hardware with plumbers putty to seal out any water. I also plumbed the water cooling lines, I'm apprehensive about the amount of water flow that the rudder pickup will deliver based on experience with ProBoat and Aquacraft boats in the family. If I am not satisfied with this TFL rudder pickup I will add another dedicated pickup next to the one I drilled in the rudder arm.
                  • Tamelesstgr
                    • Jun 2014
                    • 1516
                    I had to lengthen my temp probe to be able to reach the esc. Then I had to add some shrinkwrap and coat my datalogger with Corrosion X. Few inside shots of the layout, it's amazing how fast a bare hull fills up with wires, straps and cooling lines.
                    • Tamelesstgr
                      • Jun 2014
                      • 1516
                      Soldering of the flex cable with my crucible
                      https://www.youtube.com/watch?v=8NZuMTlDdt8
                      • Tamelesstgr
                        • Jun 2014
                        • 1516
                        As she sits right now, programmed the ESC, I might add a little extra bend in the rudder linkage, not happy with the throw
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4284
                          #27
                          Just talking out loud, but why not mount the servo closer to the transom so it could clear the motor mount and sit directly inline with the pushrod?
                          • Tamelesstgr
                            • Jun 2014
                            • 1516
                            #28
                            Wasn't certain if I would be putting the receiver box on that side or not and I went ahead and epoxied it anyway. Lesson learned to line it up better, a simple bend should take care of it.
                            • Tamelesstgr
                              • Jun 2014
                              • 1516
                              #29
                              Worked on the hatch a bit last few days, I epoxied 1/8" aluminum flat stock under the 4 corners then drilled and tapped them for Stainless M3 screws. I bought these nifty flat o-rings and those should seal nicely. Still wondering if I can find some thin membrane to line the hatch opening with. I will be using hatch tape, but would add like to add something between the hatch and hull as ProBoat does.
                              • 785boats
                                Wet Track Racing
                                • Nov 2008
                                • 3169
                                #30
                                Looks like she's ready for testing Kenny.
