I'm ADDICTED!!!!! Another Cat build
  • Spot Me 2
    • Jul 2008
    • 769
    Well, I havent finished my Mean machine build yet, and I am starting another. I picked up one of those ebay Chinese knock off hulls. I think I am going to do twin proboat or sv motor/esc's for power. I haven't decided yet, but I do know this will be a twin. Some quick picks to get you started.
    MMGMMarine
    RobertsonRacing
  • ozzie-crawl
    • Sep 2008
    • 2865
    i am doing the same hull with twins probably ammo 2300s. good luck with your build i will be watching
    • Ub Hauled
      • Aug 2007
      • 3031
      Out of curiosity,
      why are you guys building the cats with twins?
      • focused
        Dutch Electric Powerboats
        • Jul 2008
        • 237
        The sound of a twin setup is so much cooler then single , we just finished testing our HPR06 with twin setup top speed is now 101kph or 63mph .
        Setup we used is 2 feigao 540XL9 each on 6s lipo 45mm K-prop but it still needs some adjustments .
        A hpr06 is bigger and havier then the china clone so our setup is way to much , the ideal twin setup would be 2 feigao 540s8 125amp esc on 2s lipo but a feigao 380L8 on 3s lipo is also a option.
        I will follow this thread to see how you built yours .
        grtz
        Michiel
        • ozzie-crawl
          • Sep 2008
          • 2865
          i have wanted to do a twin for awhile.i like the build process plus twins look and sound cool. i have tought of the 380l8 option but wasnt sure if they would be enough to push this hull at a good speed
          • Spot Me 2
            • Jul 2008
            • 769
            Originally posted by Ub Hauled
            Out of curiosity,
            More scale looking, and I love the sound!!!
            MMGMMarine
            RobertsonRacing
            • Ub Hauled
              • Aug 2007
              • 3031
              Originally posted by focused
              A hpr06 is bigger and heavier then the china clone so our setup is way to much...
              Maybe use 540 L cans instead of the 540 S cans... lower amp draw, it'll be easier on the system... just control the speeds with the prop... if you decide to go with the L can I have 2 NIB 8L motors that may suit your application... let me know.
              • Spot Me 2
                • Jul 2008
                • 769
                What do you want for both of them???
                MMGMMarine
                RobertsonRacing
                • SLAUGHTER_AUS
                  • Sep 2008
                  • 52
                  I have the same hull with a single fiego 8l, hydra 240, with 440 prop, on 2x 2s havnt had
                  it running the best just yet though still getting things sorted, possibly this weekend i will have some luck though, will be great to see with two 540's though, i am considering a neu of some breed for this also.
                  will try till smoke?
                  www.slaughtermotorsport.com
                  • ozzie-crawl
                    • Sep 2008
                    • 2865
                    yea i have a single motor one as well runs 7xl on 4s 2p detounged x642
                    • Spot Me 2
                      • Jul 2008
                      • 769
                      Well this just got put on hold. When I recieved the hull on Sat, it was damaged. This is the second boat in a row the UPS damaged in shipping. The first was a MHZ hull and now this one. If I didn't have bad luck, I wouldn't have any at all.
                      This one is on the bottom. I could live with this.
                      MMGMMarine
                      RobertsonRacing
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        that sucks big time. mines going slowly as i have been of work sick. have managed to put the stingers on though
                        • Spot Me 2
                          • Jul 2008
                          • 769
                          Well........
                          I have one of the already painted "apparition" hulls coming now for this build. I decided to go with a single power system starting with a hydra 120 and going from there. Now I just have to wait for the thing to come fron China. It should only take a day or 2. Right??????
                          MMGMMarine
                          RobertsonRacing
                          • properchopper
                            • 6968
                            re :
                            I've been looking at this hull to replace my Drifter, but I have a question : If a single motor setup is being used, what inline strut/rudder assembly is available ? It looks like the Chinese hardware uses a 4 mm drive system, which I'd like to avoid in favor of the 3/16" stuff.
                            • Spot Me 2
                              • Jul 2008
                              • 769
                              I think you could use fullers cat hardware. I went with the 4mm hardware from the hull manufacturer. I'll change it out if I'm not happy with it. Here a pic if anyone doesn't know what they look like, but I'm sure we've all seen this before.
                              MMGMMarine
                              RobertsonRacing
