Tp 3630 and ul 1 water jacket
  • ezhitz
    • Aug 2009
    • 428
    I was wondering if anybody tried using the OSE upgrade UL1 water jacket on the TP 3630 motor?
    Thanks
    Jack
    :canada
  • properchopper
    • 6968
    Jack,
    While I haven't mated the UL-1 cooling jacket to a TP Power 3630, here's some thoughts :
    I've used this on a 3630 ;it fits nicely(if you're using a tail ring on the motor mount it's tight, lengthwise) but with the large inlet/outlet fittings and generously sized O-rings I like it a lot:
    The 3630 can is 58mm in length, the Leopard jacket (above) is 50mm long
    The HRC , very nice (but pricey) is 50.8mm long
    The UL-1 jacket is 48mm long ; I see no reason why it wouldn't fit BUT it has tiny O-rings and often requires copious lube, elbow grease and lots of obscene proverbs to get it in place without compromising the O-ring integrity
    • boredom.is.me
      • Jun 2009
      • 595
      Aren't the TP slightly smaller? Or is that the larger 40mm series?
      • properchopper
        • 6968
        The TP 3630 is 36mm in diameter
        • JohnZ
          • May 2010
          • 254
          I made the mistake when I ordered my 3630 from TP Power and bought the jacket for that motor along with it. The O rings are not installed and they have to be installed after you slide the jacket over the motor. I spent over three hours attempting to install the O rings while the jacket is on the motor. There is NO other way to do this. Th O rings were somewhat oversize and trying to install them was PITA and never accomplished.Even tried a guitar pick which only ruined one of the O rings. A stupid engineering design.
          I ended up buying one from OSE ...ham-TP3630 jacket and it fit nicely with a little olive oil for lube. LOL!
          • ezhitz
            • Aug 2009
            • 428
            Thanks guys for the input l will order a jacket when I order the motor.
            :canada
