Hello, new to the site.
I'm currently converting a oldschool Northwind 40 mono to FE. I'm new to FE boats, so need some advice on which motor would work best for what I'm looking for. I'm planning on running 4S most of the time, with occasional short duration speed runs on 6S. I think I have the motor narrowed down to a Leo 4074 or 4082 2200kv, and will start with a M440 or similar prop along with a 640 and work my way up from there while monitoring heat. My question is how much more power would the 4082 use compared to the 4074 if the prop, esc hull etc remain the same? Would the 4082 really tUrn that much bigger of a prop to be worth the extra amp draw and weight? How big of a prop should the 4074 usually be able to turn without overheating it, would it safely tuirn something like a M645 3? Here's some pics of the boat, it seems fairly heavy to me, but my little 3650 5700kv was able to get it up on a plane on 2S for about 4 minutes before finally melting the battery connector off the + wire between the bat and esc lol. The blue and red boat is the Northwind (32" long 15" beam at the transom, the black boat is a one off all wood scratch built hull my dad designed and built for me for my Xmas present last year. That project will be next in line for completion.
John
John
