Delta Force 35 in. Pirate from OSE
  • Beaux
    • Dec 2015
    • 550
    #31
    Thanks Fluid, I had the 4074 2200 kv in the mm 2 on 4s it seemed to be working to hard , 55.5 is all I could get out of her. The tp 4070 was in the pirate on 4s it was chine walking bad so I swapped them . I' like the SAW idea so I put a Swordfish
    300AHV with the tp 4070 in the mm2. My grand son wants to run the pirate. Im running M440 and X640 props.
    • Beaux
      • Dec 2015
      • 550
      #32
      I started working on my Pirate again, life happened I had to put her on the shelf. Wondering if Leo 4074 2000 kv, HobbyWing 180a, Flourene 14.8v 30c 3500mah and a x445 would work.
      Just for sport boating. Thank's for your input.
      • CraigP
        • May 2017
        • 1464
        #33
        The battery sounds too small. At 3500, the runtime will be very short! Also, 30C is only 100A, that’s probably at least where it will run. The battery needs a good de-rate, if you want it to have a long life. This is a mono, so the hull drag is high, I think you need 5000 and at least 40C, I never go below 50... Its a good boat, have fun with it!
        Oh, two of those batts in parallel sound closer to me...
        • Beaux
          • Dec 2015
          • 550
          #34
          Thanks I've got some room so parallel might work out. Thanks again.
          • ScarabChris
            • Oct 2010
            • 752
            #35
            Love it...especially the flag wrap.
            • Beaux
              • Dec 2015
              • 550
              #36
              That is paint. Thanks, I'm in the process of redoing the blue and the stars. The blue ended on the red and it should have ended on the white. I'll have some new pictures later.
              • admin
                • Mar 2007
                • 49
                #37
                Originally posted by Fluid
                I am somewhat confused. The 40x74 is a bit small for a 35" mono but about right for the MM, had one myself. The TP "4070" with a 2200 Kv is a bit much for a boat the size of the Pirate but with an appropriate prop it can work well. What prop did the OP use with it? An x447 should be acceptable but not too much.
                The above assumes 4S. On 6S a Kv of 2200 is SAW territory and generally not appropriate for a sport boat.
                Beautiful boat BTW!
                Are you using the tp-4070 cm version 2200kv motor? If yes, id suggest sell the seaking 180 and get a 300-400 amp esc. Otherwise, you might end up with a paper weight of an esc rather quickly.
                the tp-4070 2200 on 4s
                • Beaux
                  • Dec 2015
                  • 550
                  #38
                  No, I down sized to a leo 4074 2000kv for my grandson to run. I put the tp 4070 with a sf 300a in my Mean Machine 2.
                  • admin
                    • Mar 2007
                    • 49
                    #39
                    Really? that should be interested to witness. Make sure to video. :-)
                    Its a bit small, id suggest 4s max with a smallish sized 40mm or so prop.
                    • Beaux
                      • Dec 2015
                      • 550
                      #40
                      I have a x 445 prop. It's for my grandson to learn with. I know there's room to grow with it.
                      • ScarabChris
                        • Oct 2010
                        • 752
                        #41
                        Dayum...love it even more now!
                        • Beaux
                          • Dec 2015
                          • 550
                          #42
                          You ought to see my Mean Machine 2 painted like the Texas flag ,nice.
                          • CraigP
                            • May 2017
                            • 1464
                            #43
                            That’s still sounds like a big prop at close to 30,000rpm for a young driver. 440 to 442 sounds more reasonable.
                            • Beaux
                              • Dec 2015
                              • 550
                              #44
                              I've got a 440. Sounds like a good place to start. Thanks.
                              • Beaux
                                • Dec 2015
                                • 550
                                #45
                                I got the blue and the stars repainted last night, going to pick up the clear this morning. Should have it shot by nine.
