Outboard pursuit
  • ls1fst98
    • 859
    down the center works great for my pursuit. mines conventional, with the motor to the very back, batteries on a tray down the center.
    • Outboard
      • Jan 2016
      • 50
      Originally posted by Beaux
      What size motor are you running. That boat looks good with an outboard.That's a good esc I'm running one in my DF Pirate.
      Running a 3659 1900kv on 6s
      GO HARD OR GO HOME
      • Outboard
        • Jan 2016
        • 50
        My batteries seem upfront but that is to counter balance the outboard hanging off the back
        GO HARD OR GO HOME
        • Beaux
          • Dec 2015
          • 550
          She ought to fly.
          • Outboard
            • Jan 2016
            • 50
            I am a little worried that the leads from the esc to the motor may be too long. I had to make them this long to rout the wires neatly and away from the steering/servo. what do you guys think??
            Also these terminals come on the motor from factory, will they be good to use or should i use 5.5 connectors??
            GO HARD OR GO HOME
            • Outboard
              • Jan 2016
              • 50
              She ought to fly.
              I hope so, depending the prop, not sure what will work well. I have a 4414/3 for it. Any suggestions greatly appreciated
              GO HARD OR GO HOME
              • boilo56
                • Aug 2014
                • 390
                I would try 4014/3 first, just to be on the safe side. But My boat does not run an outboard motor, so i might be wrong.
                Regards, André.
                • Outboard
                  • Jan 2016
                  • 50
                  #23
                  Regards, André.
                  What motor and esc you running?
                  GO HARD OR GO HOME
                  • Beaux
                    • Dec 2015
                    • 550
                    #24
                    The connectors look a little lite if you have 5.5's I would change them. 6s is pretty hot. The prop you have should be ok.
                    If your running a hobbywing 180 6s will smoke it'
                    • Outboard
                      • Jan 2016
                      • 50
                      #25
                      How will I smoke the Hobbywing 180 ESC? Because of the connectors or the prop and motor combo?
                      GO HARD OR GO HOME
                      • Beaux
                        • Dec 2015
                        • 550
                        #26
                        6s is 22+ volts and many mha's if you run 40mm or less prop it may last awhile, is your motor rated for such voltage . I have a similar size f1 hull with a 3650 leo 2200kv and 5s is way too crazy.
                        • Beaux
                          • Dec 2015
                          • 550
                          #27
                          Go to the electronic talk and pull up esc's there you can get a lot of info on our particular esc along with cooling mods. check it out.
                          • Outboard
                            • Jan 2016
                            • 50
                            #28
                            You are getting me worried, I run this same motor with a 120a seaking esc with a 2 blade 42mm prop 1.4 pitch with no dramas at all.
                            GO HARD OR GO HOME
                            • Beaux
                              • Dec 2015
                              • 550
                              #29
                              Just run it and chck the temps being its such a small boat you may have no problems, just check your temps.I've run mine on 5s in my mean machine approx. 4 mins. and it was pretty warm.
                              your specs say its ok so run it thats all I was worried about 6s is almost 40,000 rpm, it ought to fly , have fun is the main thing.
                              • Outboard
                                • Jan 2016
                                • 50
                                #30
                                Just an update, pretty much everything is mounted in position, i also did a float test to check for leaks etc. No leaks and floats nicely.
                                GO HARD OR GO HOME
