Hpr 99 ultimate layup.
  • pond skipper
    • Sep 2010
    • 175
    Well my hull and hardware finally arrived today! All I can say is amazing!!! I've never seen this kind of attention to detail put into a rc boat hull and it will take nothing short of an act of God to break this hull! Excited is a HUGE understatement! I will post some photos of it on here later today when I get a chance to one, calm down, and two, to go on lunch brake, I swear if Hanspeter were standing in fron of me I'd kiss the man lol! For those of you who run cats you should really really look hard into purchasing one of his hulls. For the strength, quality, and attention to detail it should cost easily twice as much as it did..
  • pond skipper
    • Sep 2010
    • 175
    interesting how the drives attach to the hull, hopefully that knurled nut will be enough to hold them in place and not leak, will probably put some silicon rtv against the face of the outdrives to seal them against the hull.
    • SANTAVY1
      • Jan 2011
      • 135
      Hanspeter builds amazing hulls period!!!!! I have had 3 of them and still have 2 one is signed by him.
      • Tamelesstgr
        • Jun 2014
        • 1516
        Dam, that is a sexy hull....
        NEVER SATISFIED RACING
        Fine Design 32 V-Hull 4082+6s
        • pond skipper
          • Sep 2010
          • 175
          No doubt! And thanks!
          • dmitry100
            • Mar 2015
            • 1264
            Do the drives have ball bearings or bushings?
            • iridebikes247
              • Dec 2011
              • 1449
              Nice man, they're beautiful hulls.
              The nut will be strong enough to hold them, without question.
              If you measure enough times you should be able to get the drive pedestal to fit while still having a tiny bit of bite so you can screw in by hand but not a totally "loose fit," a tiny dab of silicone during installation and you can cross drives off the checklist
              • pond skipper
                • Sep 2010
                • 175
                The drives are dual ball bearing on a a 6mm shaft that's turned to 3/16 on one end (prop end) and bored out on the other to accept a 3/16 flex cable
                As for the measuring, once I get things situated the way I want I will be making an aluminum drill teplate that can be used to drill out the pilot holes for the drives themselves and keep everything equal and identical.
                • dmitry100
                  • Mar 2015
                  • 1264
                  You mean you're gonna shape aluminum plate to the back of the sponson for the drives?
                  Perhaps instead you can use something like a sheet of really thick paper or plastic-- but still thin enough to use scissors and then just use masking tape to align it...
                  I use a 0.5mm thick (black) fiberglass sheet for these things since I could easily cut it with scissors but allows for clean pilot holes, etc. And I also use it the sheet to make ESC mounts, etc. :) Easily cut out 5 layers of the design you want with scissors and then epoxy/cement each layer together and boom... a strong plate.
                  • pond skipper
                    • Sep 2010
                    • 175
                    yeah I thought about doing something like that to but for me its much easier to make it from aluminum or even stainless as I work in a machine shop and have access to some FINE milling machines and plenty of scrap material, aside from that if by any chance something ever happened to the hull, god forbid, I would have a set of templates that would last a lifetime for drilling the same holes in a new one.
                    • dmitry100
                      • Mar 2015
                      • 1264
                      Well, it's an ultimate layup. Have you seen the huge amount of caulking or epoxy of some sort in the front of the hull to keep front seams from separating? I wonder if that's unique to the Ultimate layup or for bulletproof as well... But it is about ~1/4 pound heavier than even the Bulletproof though (which I would assume is plenty of extra carbon). I do wish the hatch came a bit more reinforced like the rest of the hull though...
                      • pond skipper
                        • Sep 2010
                        • 175
                        The hatch on this one is probably just shy of 1/4" thick, infact it's more than that in places, it should hold up well. All I really have to figure out now is if it would be better going with 1/4" sst stuffing tubes or the traditional brass 5/16" with a 1/4" inner tube as a replaceable sleeve for the larger one, kind of like a bushing that runs the length of the flex cable. That's how me and my dad always did them but with the way these drives are made and the new style stuffing tube clamp mounts that can be unbolted you can literally remove and replace it without having to cut anything loose in the hull so I'm leaning towards just going 1/4" stainless, that plus I have a super nice set of swagelok 1/4" tubing benders which would be perfect for the job.
                        • pond skipper
                          • Sep 2010
                          • 175
                          I basically told Hanspeter when I talked with him through email that I wanted it to have to take an act of God to break this boat which might account for my hatch cover being so thick.
                          • dmitry100
                            • Mar 2015
                            • 1264
                            Not sure if he does "custom" work, as most of those hulls are in fact already done before you order them. Can you take a picture of the hatch and maybe a caliper reading of thickness-- I'll compare it to mine. Or maybe just weight? Mine is Ultimate as well. So far hatch and all looks the same.
                              • 7673
                              Very nice. This is an awesome sized boat and will be killer on the water. I have yet to build my 115 but the quality is second to none(AC boats being next I think).
